[ROM] ACE ROM v2.0 (No Further EC05 Development)
Would you like to see the CIQ Removal in the next release of ACE?
  • Total voters
  • Poll closed .
Let me start off by saying Ace is the only rom that I have had any interest in flashing. I have not been disappointed. I have not had one issue and to be honest I was not expecting to. Keep up the good work Paul, I expect your future roms to build on the success that you have achieve with Ace so far. I do have a request though: I am a big fan of Launcher Pro and was wondering if you thought about adding custom icons to the dock bar!?! Adding custom icons that corresponded with the wallpaper that you included would had got you a ten out of ten in my book. Since they were not included, your rom receive a 9.95, lmao! If this is something that you can accomplish, I need some lime green ones to go with the lime green droid wallpaper!
Having some cool custom ACE LauncherPro Icons would be nice ( hint - hint )
I still have the tw locks creen zip from dk28 but I'm thinking if I flash that it will cause problems. Is there a zip for ec05 that I can flash?
I've messed with you ROM for a couple of days now and like it a lot.
Looks pretty stable for me but I'm going to install my favorite Aquarium live wallpaper which seems to strain the system and see what happens.
I deleted the stock messenger and have been using chomp sms. I know longer can recieve text messages. I can send them though. Is this because of Ace? Same setup on stock and had no issues. Any ideas?
You cannot delete the stock text messaging apk (mms.apk). You should leave the standard mms.apk in /system/apps and just use chomp sms instead (change launchers to launch chomp sms instead of messaging).
I hate the stock mms, so I use the AOSP mms.apk. I REPLACED the mms.apk with the AOSP mms.apk..
To avoid the dual notifications using chomp sms, disable notifications in the stock messaging app..
Reactions: Kdrickdynasty
where can i get the mms.apk or aosp mms.apk that is compatible with ace rom?
Here ya go :)
**EDIT** By the way, this is the AOSP mms.apk. Use Root Explorer (pay for in Market) or Ghost Commander (free in Market), navigate to /system/app, mount r/w, and paste this in there. For those of you who havent tried it, I suggest making a copy of the stock mms.apk so that you can replace this one if you dont like it. I cant stand the bubbles crap, and this one looks like Eclairs only with images for the users. Hint: If you want "Me:" to have your face, create a contact named "Me" in your contacts list and add your own picture- works perfect.
**EDIT2** If anyone wants the stock one, you can get it by downloading ACE (or most any ROM actually), extracting the zip into a folder (on your computer), navigate to /system/app and copy the mms.apk to your sdcard.
Hi guys, anyone know what it means when I'm running oneclickroot for EXT4 and it says "installing busybox" no more space on device?
Just got my phone back from Best Buy on Friday. Rooted and installed ACE Rom this morning..so far the smoothest Rom I have ran so far! Thanks Paul!
No I did not add those into this version. If/when I do another update it will be included.
I did notice those are available in flashable versions so you can flash them while running ACE.
yes. i flashed the updated bionic noticed a little bit more snappiness. but excellent rom buddy! i'm coming from bakedSnack --> bonsai --> ACE.
I noticed few ppl are having freezing issues so lets see how it runs on my phone. Does the genocide kernel have root in it? just in case I do encounter freezes and want to switch kernels..
Good to hear on those updated boinic and the lib files. Honestly I forgot to add those in and didn't even think about them until you just mentioned them.
Genocide does have root in the kernel.
Forgive my stupid question, but do you apply the updated bionic and lib files as an update.zip or as a normal .zip?
Just flash them like you would a ROM, no wipes required.
The "apply update.zip" function however its worded will only work if the flashable is named "update.zip" otherwise it won't work.
Reactions: readingkeeper
So I customized this rom to my liking!
I found Genocide kernel gives a MUCH MUCH better fluidity and smoothness to the rom. I'm running 100/1120 ondemand. Maybe you can switch twilight out for genocide in the next release?
asnes
