ROM ALERT: Baked Snack v1.6 [update6]
hey rag,
i have a question about flashing mixup kernel.
i tried flashing it and it wont work for me and i currently have baked snack 1.0 flashed.
and i was also wondering how to flash a kernel?
do i just do the same thing as flashing a rom? because what happens if i want say baked snack rom and mixup kernel?
do i wipe? and then flash the kernel first then the rom? or what?
i just need the order of instruction i dont need a step by step
thank you!
hey rag,
thank you!
Kernel flashing is a more straightforward and less involved process. Unless you're having problems, usually you don't need to wipe before flashing a kernel. Flashing a kernel and a rom involve the same process - boot into clockwork and install the zip file.
If you want to mix and match roms and kernels, always install the ROM first and the kernel second. If you install the kernel first, installing the ROM second will overwrite the kernel with the one prepackaged in the ROM.
For the MixUp kernel, under Settings>About Phone>Build Number it should read: "SPH-D700 - Tha Boss ROM - MixUp Custom Kernel". Don't worry about the part that says Tha Boss ROM. It only says that because this kernel was originally custom made for Tha Boss ROM and later released as a stand-alone kernel.
Let me know if I wasn't clear enough or you need more detail.
that was perfect. in fact it was more than i asked for. thanks!
i have one more basic question. do i need to leave juice defender running in the background? can i just hit the back button so its not in my (samsung-built in) task manager - but the icon is still in the status bar?
because i leave the "enabled" button on but im curious as to whether or not its working in the background without it being in my task manager
The Samsung Task Manager is crap. If you get something like Advanced Task Killer you'll see that the stock task manager doesn't show a lot of apps that are running/in the background, so don't worry about if it shows up there. Just make sure it's correctly enabled, which it sounds like it is.
Update: v1.3
Change Log
v1.1 (not publicly released)
huge tweaks to dalvik vm
kernel based on di18
eliminated app shutdown / startup lag
kernel tricks for faster boot
voodoo color
most updates from ota without rebasing (weird root issues from new base)
increased battery while on wifi
fixed 3g uploads
1.3 ghz overclock because 1.4 was acting weird
use overclock widget to overclock
slight kernel tweaks to video recording for faster framerate
more tweaks to conservative governor to insure very fast clock switching
zipaligned all apks and did heavy manual modding for speed/battery
removed: mediahub/drm/sprint tv/my files.apk
added removable apks: astro
phone now boots and runs at 800mhz with stock settings
integrated bfq scheduler
new innovative votage scheduling tweaks for amazing battery
may have issues on first boot but it is only at first boot
try to use manual brightness. as voodoo color fix can act odd with auto brightness
v1.2 (not publicly released)
fully based on di18
fixed 3g speeds
boots at 1ghz
much improvement from di18
fixed pandora
tons of theming goodies
themed dialer by raiderep
new undervolts (amazing battery, literally amazing)
1.3ghz now runs at the same voltage 1.0ghz used to use!!!!! (no battery hit with outrageous performance)
musicmod
apps on data (uninstallable) : adw launcher, superuser, thinkfree office
apps loaded to /sdcard/app/ : astro, nfl , overclock widget, working wifi tether
made memo and my files uninstallable
reworked kernel with new toolchain (stability)
themed crapsung widgets
icons from sense ui
few kernel config tweaks
removed tun from kernel build
kernel built with cortex 8 optimizations
removed boot sounds
added galaxy s logo on shutdown to let you know when phone is actually off (thanks schizzo)
media force close on first boot (dont worry, nothing is wrong)
removed initial market lag
symlinks to busybox
added htcime mod keyboard. baked mod theme thanks to gimpsta
best battery around
v1.3
lots more theming
updated market-no more lag guarantee
should have fixed fb sync issues with calendar
htc ime is now on sdcard (install htc ime and clicker apks)
prettier samsung widgets
added usb tethering support from mkasick
removed mobile ap framework
updated busybox
faster bootup
reboot after first boot for best performance
My quadrant scores went from around 950 to 1019 after the update.
I was just beginning to wonder if an update was coming. So happy. lol
Flashed this last night and I am very impressed. No issues at the moment and just enjoying the speed. Linpack was 10.6 and on Eclair that is pretty impressive. Everything is just a little bit snappier and I am getting the same if not better battery life on 1.3ghz conservative profile. Also, the phone boots very fast.
This is definitely one of the best ROMs I've ever run. My only problem was instability at 1.3GHz, so I had to dial it back to 1.2GHz but it's still scary fast.
I have no problems at 1.3 GHz, but my facebook profile keeps doing weird things.
I love this ROM.
I had to do the same when I flashed this ROM. It was crashing on me a few times when I had it clocked at 1.3, now at 1.2 it smooth and still super fast.
My config is min-200 and max-1300
I'm usually using conservative profile but kept it on performance for a little while for benchmarking. I have been lucky and have not had any crashes.
I also did a complete wipe twice before flashing and I restored my info using Titanium and not recovery if that matters.
I also have to say the mario powerup notification sound is awesome.
can anybody help me out with overclocking? i know the kernel is over clocked, does that mean we don't need to change anything? I am running baked snack, either 1.2 or 1.3. not really sure which, my downloads folder says 1.3 but my phone "firmware" says 1.2. either way i'm not sure how to go about overclocking my phone, but i do have set cpu if needed. thanks guys!
Go into setCPU and press the auto settings. Finally, just slide the bar to max and you're good to go. If it is stable, you can have it set on boot too.
Will phone settings be erased?
I apologize if this question has been answered elsewhere...
I have Clockworkmod and titanium loaded on my phone. If I flash this ROM will I lose all my apps and settings? If so is there a procedure to follow so that I don't lose everything?
Thanks.
YES! It's awesome. The only time it's inconvenient is when someone is playing Mario within earshot, so other than this past weekend...never.
albrens
