ROM ALERT: Baked Snack v1.6 [update6]
Thanks. I did go down to 1.2Ghz. At 1.3Ghz my phone would lock up with 10 minutes depending on the activity.
I think I changed the Set CPU settings and that may also have some impact on these issues. Please let me know what has been working for you.
Thanks.
My SetCPU settings: 200Hz min, 1200Hz max, Scaling conservative, Set on Boot checked. With this setup I have a very fast phone with great battery life.
As for the launcher I'm using ADW.
Any luck using mixup kernel with this rom? About to flash right now.
MixUp should work fine with the Baked Snack ROM, but I don't know anyone personally who has that setup. Let us know how it works for you!
So far, it is running very smooth. I'm currently calibrating the battery, so I won't have any battery data until tomorrow (hopefully!). I'll do some benchmarking and post results momentarily.
UPDATE:
Quadrant @ 100mhz / 1.00ghz: 974
Quadrant @ 200mhz / 1.2ghz: 1024
First full charge from 100% to 0% took 17 hours and 25 minutes. In this time, I spent ~3 hours running psx4droid, with another 4-5 hours of moderate to heavy use. I typically charged after 6-7 hours after an equal amount of use. Baked snack 1.3 with mixup kernel ftw!
How do you calibrate the battery?
You charge your phone to 100%, reboot into clockwork recover> advanced> wrote battery stats.
Let your phone discharge to 0 (let it die) and recharge to 100
Sent from my SPH-D700 using Tapatalk
i keep on reloading his website page for the epic 4g downloads hoping ill see 1.4 but to no avail.
Hero_Over said the earliest v1.4 would be released is today, and if not today then very soon.
no like i said they are having issues with it right now...
you said ....
it's 1.3 ghz overclock because 1.4 was acting weird so we might not see it for a while..
which means you thought i was expecting 1.4 ghz overclock like his original kernel was.
i am talking about rom version 1.4....
hes not having problems with it. he was supposed to be releasing it this weekend. last time i checked he said he was going to use it all day friday to make sure theres no bugs and release it this weekend.
The link to v1.4 is up on Hero_Over's forum. I will change the thread title and first post once the release goes public. Installing now :D
wtf please email me that shizzzz.
i keep trying to get into the forum but i cant get in no matter how hard i try. gosh or maybe a link or something
or maybe you shouldnt have said that and just let it ride out for us normal folks that cant get into his forums cuz its kind of dumb how he has to approve you. and from what i can tell hes too busy doing other things to approve me
You should try e-mailing again to let him know. He's usually pretty good about that stuff.
Tiokujha
