[ROM ALERT] Myn?s Warm TwoPointTwo - [RLS 4 - 11/25/2010] - Making Sense Of It All!
You'd bet wrong then. Lol. I have a 2.5 version.
Shenanigans... UR SD is prob Corrupt then... only thing i can guess
Personally I moved away from Clockwork because of these intermittent issues
every once in a while it would act funny with me...
I moved to Amon RA *The Other Recovery* and I haven't had issues...
Reactions: MissJennell#IM
I should try that one then. I am currently formatting my sd card. I will then put a ROM on it and see if I can flash it. What all am I going to need to put on the sd card before I flash the ROM to the phone?
And thank you for your help. I definitely appriciate it very much.
Honestly you just need to have the Rom the phone will take care of the Rest...
Once ur all set up though.... Easiest way to flash a Recovery is Rom manager...
Scroll all the way down in Rom manager and click flash Alternate recovery
It will be the newest AMON
I used that alternate recovery last night. Then switched back this morning. Maybe that effed it for me. Lol. We will see. My card is almost done formating. It's a good thing I don't have to work today *sarcasm*. Haha.
Pshhhht Set up ur game I am at work haha :cool:
I'll be here just post up let me know how it goes most def...
*Congrats on pulling me out of Ghost mode*
Now it fails and says
E:Can't symlink /system/xbin/[
E:Failure at line 15:
symlink busybox SYSTEM:xbin/[
Installation aborted
/sigh
I use Myn as my daily and have never experienced that. I'm using RLS 4 with the stock #17 kernel and battery life has been solid. Today I've been off the charger about 3 hours and I am at 91%.
Did you do a full wipe before flashing the ROM? Do you have a lot of apps installed?
Yes did full wipe,no only a few apps on phone and I went in to manually close the ones not being used. hell just getting to ac to look at this thread and to answer burned up like 9% of battery. Might try to re-wipe and then re-flash after work. Rim seems to work great until I go to do anything in the phone
Unrevoked 3 and then unrevoked forever.
-____-
I won't say a word... *If you dont know how I am research my Username a bit and ull see my dislike for said Method*
If you cant get the thing working Run the RUU and redo ur system
This time Root with the ADB Method I won't get into the reasons here
-____-
I have been trying to get it working and to do the RUU. It can never find my phone.
Do you have HTC Sync installed? *Never had the need to do an RUU Im not the best to ask this question*
I have the proper drivers installed. It doesn't seem to want to work. I am not sure what else to do at this point. But I will keep trying. I have had to go back to my epic until my evo is up and running again. And I am hating my epic.
Drivers are one thing... Sync is another... *Don't mean to sound like a ****** although others will argue I am one*
Try again with HTC Sync Installed
You can also try Flashing one of the PC36IMG Files in Fastboot to get you up and running Download Rom Manager Flash Amon RA and Try Wiping and Flashing again...
that could be a workable Solution for you
slackingfred
