[ROM ALERT] Myn?s Warm TwoPointTwo - [RLS 4 - 11/25/2010] - Making Sense Of It All!
With the radios update 4g works,any way we can get the rom updated with newer radios so we can keep rom as is
typically the roms do not update the radios....usually they only get updated if you manually update them or if you install a rom that updates them automatically such as sprint lovers....or thru the OTA updates.
just so happens the rooting method i used and many others use....it flashed the sprint lovers rom which updated all the radios. then i flashed myn rls4....then noticed some issues...after some reading found that the 1.90 pri doesnt play well with a 3.30 base rom (rls4)....now when rls5 comes out you can flash back to the 1.90 pri which is for the 3.90 base (the latest ota update)
Reactions: dased1
I was on one of the 3.x ones. I flashed 2.6.0.1. So will try again and see what happens.
you shouldnt have any problems now with the 2.6.0.1...i read alotta people were having random issues flashing any rom using clockwork 3.x...it was due to the update scripting or something or another that is kinda over my head.
ive had amon ra 1.8 and just updated it to 2.1.1 today. so i dont have any experience with clockwork.
Reactions: MissJennell#IM
Ok,i had a radio zip I used it gave me something like pri v1.3 and baseband 2.15 <- (if I remember right is the newest radio update
like i said it seem to change a few things nothing to bad.thx for the clear up though.
Next task flashing new themes like lock screen and start up anime
This ROM seriously hates my EVO. I tried flashing it with 2.6.0.1 and it didn't work right. It kept freezing my phone and resetting after it was flashed. So I downloaded the zip to my computer and then put it on my sd card. Then put the phone into recovery mode and flashed it. We will see if it actually works this time.
Try it with Amon_ra, do a full wipe (data, cache, everything). Its on the stock HTC kernel so you shouldnt have a problem.
thats the same routine i used....but like i said before i used amon ra....myn actually recommends that instead of clockwork....so i would agree with igotsanevo4g and try using amon instead and make sure to wipe the cache/delvik.
hopefully this 3rd or whatever try your on flashing will get it to work correctly lol
So I am flashing the RA 2.1.1 right now and then will do the rest. Hopefully it will work.
You and me both. Lol.
howd it go?
i forgot to mention if you had a problem using amon 2.1.1 during the beginning of the install to toggle the signing verification off before flashing...thats a new feature in 2.1.1 so if a dev doesnt sign the zip you have to toggle that or you will have install errors.
Is 27% battery lost in 4 hours the norm for this rom. Only sent 3 text,1 mms, and Twitter only updates once an hour, no email set up yet.
I use Myn as my daily and have never experienced that. I'm using RLS 4 with the stock #17 kernel and battery life has been solid. Today I've been off the charger about 3 hours and I am at 91%.
Did you do a full wipe before flashing the ROM? Do you have a lot of apps installed?
I did a full wipe and flashed this rom but it never booted. I got stuck at the htc screen for 10 minutes.
howd it go?
It went okay. At least it doesn't freeze on me now. Almost every app forecloses on me though. So this morning I am going to flash a different rom. I definitely can't say I didn't try with this rom. Lol.
did you wipe Dalvik?
Is everything is FC'in then you need to Reflash the Rom...
Do a full wipe Data Cache and Dalvik Then Flash
I have done all that 8 times now. I am definitely done trying to make this ROM work. Maybe when the next one comes then I will give it a try again.
Edit: It now won't let me flash any ROM. It ends up saying
assert failed: write_raw_image("/tmp/boot/img",
"boot")
E:Error in /sdcard/*whatever ROM zip I am putting on*
(Status 7)
Installation aborted.
"boot")
(Status 7)
Sounds like the Issue Koush was talking about with the Recoveries...
Can you restore a Nand Backup?
I can't do anything. Everything ends in a error.
Ur SDCard might be Corrupted... u obviously have access to a computer...
IN AMON you can format ur SDCard Go ahead and do that do a full wipe
on ur PC Re-Download Myn or whatever Rom you want...
Mount the SD thru Amon Drop the Rom onto the SD and try to flash again
Amon?
byronsss
