[ROM ALERT] Myn?s Warm TwoPointTwo - [RLS 4 - 11/25/2010] - Making Sense Of It All!
I installed this ROM for the first time yesterday and love it! Can someone explain the difference between the kernels available and how they are different?
I am new to my EVO and the whole flashing Roms, and have encountered an issue when trying to flash this Rom. I moved over the Rom zip file to the phones sd card, wiped the data, the cache and then tried to restore from a zip on the sd card. I found the Myn zip file and once choosen it started to work, but aborted in the middle of the operation. Can anyone help with my issue?
I assume youre using clockwork recovery? Make sure you have the latest.
Next also wipe dalvik cache as well, in clockwork its under advanced.
Other than that, theres not a lot of information here to go by. What else have you tried? Can you sucessfully flash other roms?
Clockworkmod has been a cause of tons of issues as of late, Give some info on what version hboot and which clockwork(if you have it) do you have....
I heard RA plays well with myns also...
Thanks for the info. I figured it out last night, myn is not playing nice with the latest release of clockwork. I had to use a different recovery program. Thank you for the help.
how and where do i get the amom-ra recovery and i seem to be having a 4g issue stays scanning i did a full wipe. not sure which recovery i have or where to look and see whats on ther. any help would be great. but i do like the rom just need 4g working
You can flash from rom manager or here
your welcome ;)
ps your 4g usually has nothing to do with the recovery...you have some other isuue
give me some info and i will try to help
thx, anyone now how to fix this 4g problem, wifi tether isnt as good if i can't use the 4g connect
i have ra recovery v1.8 is this the latest one?
baseband 1.36.00.04.02
pri v1.34.003
prl v60674
and should i reboot or anything after i flash this ?
was working in ac-rom rebirth and one that i used to root called sprint-lover from xda.
was having a few problems with this rom at first , gallery wouldn't show pics, media wouldn't show or play songs or ringtones, kept powering off and on but that all seems fine now only problem seems to be that 4g is (a) not picking up signal anymore or it is stuck in scanning loop.4g mac has an address in hardware, dont know if any of this helps
just thinking out loud here but arent the radio at like baseband 2.15 or something like that? how would you flash update radios
does this rom have the updated radios???
I put this ROM onto my EVO tonight and when it rebooted the touch screen wasn't working at all. I am not quite sure why. I flashed back to cyanogenmod 6.1.2 and it was fine. I really wanted to try this ROM though so I am disapointed it was like that.
Edit; Could it be because I used clockworkmod recovery?
No have pri v1.34_003 but now running baseband 2.15.00.07.28
Only looks to have taken off rom manger and wifi tether,custom market
which clockwork did you use....there have been many issues with the new clockwork 3.x series...2.6.0.1 should be the one that will have no problems
With the radios update 4g works,any way we can get the rom updated with newer radios so we can keep rom as is
sellhousefastmke
