ARCHIVED: [ROM][ALPHA] quattrimus ICS
Status
Not open for further replies.
Re: [ROM][ALPHA] quattrimus CM9 (ICS)
If I'm coming. From iho how do I go about exactly I have an idea just wanna make sure
Reactions: gpoppa
So am I just blind? Is there any setting to speed up the scroll speed on cm9. I'm so used to scrolling fast with cm7. Am I missing something? Thanks
Sent from my VM670 using Tapatalk
No settings, but I'd guess there's an xml in the framework that governs the scroll settings
Reactions: pbailey212
I saw this in another forum and thought I'd share it here giving credits to the provider.
http://forums.androidcentral.com/lg...-29-zvd-basesband-alpha8-100.html#post1681785
"If MMS doesn't work. I know some guy creating the ICS rom for thunderbolt took the mms.apk from the nexus and did some stuff to it and got MMS to work." Pimpjuice1992
I'm wondering if this is a possible fix to the frustrating MMS fix. Does anyone know if it will work?
I doubt it. I think the issue is in the networking. Which is one of the reasons I'm working on the new ICS kernel.
are you going to base your next build on 4.0.4? ive been trying to build cm's source and im having problems and im not sure if thats why or not.
Reactions: gpoppa
It will use whatever is current in CM9. I think that's 4.0.4 now but I'm not sure.
ok i loved it plz gie me an uodate!!!lol cant wait till everything is ready to go
ANyone got Netflix to work? all I got is blank screen and audio... :/
Reactions: gpoppa
Netflix is not working on CM9 ICS yet, neither is Flash.
Devs are just starting to get some of that stuff, but other things are taking priority.
But YouTube works pretty well now, and I believe that requires Flash; so some things might work but not all.
Youtube app does not use flash. The mobile version of the website doesn't either. The desktop site is the only one that does, but that will likely move to HTML 5 soon
Older, and some newer Youtube uses flash. Search for songs, you will find a LOT is not there on your phone compared to computer.
A lot of newer Youtube is using the H.264 video system. Those will work on your phone, Flash will not.
My camera/gallery doesn't work..what's up with that?
Camera works, just no preview. Gallery will be broken...until it's fixed. I recommend Quickpic in the meantime, it's on the market and an awesome replacement.
Status
redmercer
