ARCHIVED: [ROM][ALPHA] quattrimus ICS
Status
Not open for further replies.
@heretic1990, it's not that I can't use Titanium Backup, just you have to touch the "install" button for every app. Would be better if you can "INSTALL ALL" without having to do each one separately. I know there's the batch option, but it doesn't install every one of the apps without having to wait for the install to pop up.
If you have the pro version you don't have to press anything but restore or run from the batch menu.
Sent from my LG-VM670 using Xparent Purple Tapatalk
That ability is in the paid version.
Sent from the BACKside of Tapatalk
Exactly. The only non system apps I have are tapatalk, Facebook, adfree, and some sound recording app because I can't stand to click install ten million times. What they need is (like you said) a way to bypass asking everytime.
Don't know what to tell you then, I quit pirating software after I took a programming class. It sucked so much I decided professional programmers deserve my money.
You know what? You guys are actually right I shouldn't be doing stuff like that. For that I have decided that I'm going to Uninstall the one I have now and Getty the one on the market plus the, license
You know what? You guys are right I shouldn't be doing stuff like that. For that I have decided that I'm going to Uninstall the one I have now and get the one on the market plus the license.
Reactions: brotherswing
Reinstalled alpha 8. This time flashing gapps before first boot, and my market issue, apps i had bought in the past showing as not purchased, is gone.
However, camera won't load at all.
Sent from my cellular telephone using Tapatalk
Reactions: tdm
Hmm quick info catch up.... okay every freaking time i install this rom(cm9) ill play around with it for like 5 mins and the phone freezes and reboot more then i turn the dang thing on auuggh! plus i would wanna help with this rom in anyway necessary:) also i was thinking of using the V6 script to increase or stabilize the multitasking. thanks guys for creating such a great rom yet i cant wait till the beta phase of this:):D
Any idea what's special about the new CPU governors I see? msm7k, scary and Savagezen?
tdm,
I did a clean install of your AOKP release and I see why people like it better. Wifi worked right off the bat, but 3g is another story. It does freeze up a lot and the phone reboots itself after about 20 to 30 seconds. I have been trying different OCs mentioned in another post, but haven't found a stable one yet. Any suggestions on the best setting or is it phone dependent? Also I keep getting a USM(?) warning when it first boots up, whatever that is. It wants me to connect USB.
I see you told someone a few pages back not to use link2sd as there would be problems since AOKP installs apps to the external sd partition. Is that right? What should the partition be formatted to? Fat32 or one of the other options? I ask since I had formatted it Fat32 originally and I can't tell if anything was put there. What should I find there if I use an app like Astro?
Thanks for your time and all your hard work, I really appreciate it.
Germitty
Status
BrüZZi
