ARCHIVED: [ROM][ALPHA] quattrimus ICS
Status
Not open for further replies.
alpha 7 is released:
quattrimus-vm670-cm9-alpha7.zip (quattrimus-vm670-cm9-alpha7.zip)
md5=c7e0b9321fdc54862cf41f925c64f454
Changes:
* New kernel forked from Drew's gingerkernel. Added network stats module (xt_qtaguid) and native keymap for the VM670. I think data usage works now (not that we care).
* Pulled in a bunch of changes from lupohirp. As a result:
OpenGL is working for games. Tested Angry Birds, Cubes Free, Hamster Attack, etc. I did observe on an earlier build that sometimes the GL libraries get cranky and the games hang, so it's probably not perfect yet.
Video works. Specifically YouTube.
Camera is partially functional. It can take pics but the preview window and video are still broken.
Keyboard now renders correctly.
Beginnings of native usb storage. Not functional yet but I think it might work eventually.
* Synced with CM9. Many things are fixed. Most noticeable is probably the numeric battery indicator.
* Fixed up some build definitions and overlay files. As a result:
Lock screen now says Virgin Mobile at the bottom.
Voice mail notification calls the correct number.
Other stuff that I can't recall.
* Added CalendarGoogle, GenieWidget, Talk, and YouTube back from gapps.
* Recoded the VM-specific MMS logic to be less hacky. Not tested yet because I don't have anyone to send me an MMS right now. (awww, poor lonely me).
Also noticed that Pandora works now. Don't know what was broken but I'm not complaining. :D
On the downside, the ROM has grown again and will probably need to go on another diet soon. The system partition is about 90% full (148m of 164m used). Some of this is caused by the OpenGL libs and the new gapps apk's but there's also some additional bloat in other things. Most notably LatinIME has grown by 1.8mb and there's a new CM9 ringtone named CyanTone that weighs in at 1mb.
A long time ago TDM, you said you grabbed some files to make pandora and youtube work... think you could do that again for AOKP Alpha 8? I want my pandora back! :(
The update to 4.0.4 seems to have broken several things. I'll need to figure out how to fix them. Feel free to go back to alpha 7, it was in many ways a better build.
Reactions: zoidberg_md
Well, the process of debugging is largely removing the bugs you've found while inserting new ones to find later. :D
Sent from the BACKside of Tapatalk
I can't seem to download the aokp file it always says download unsuccessful
if you are downloading that on your phone, the problem might be that you don't have enough space on the sdcard. Another problem could be if you are on froyo, since I don't think downloading zips works on froyo for some reason.
i downloaded the cm9 alpha 7 just last week.
most likely, as others have indicated, MMS will start to work when 3G stops dropping. Tdm already tried fixing the apn a long time ago and discovered it didn't do anything ):
Can we possibly tests this though to confirm? Can someone turn EvDO off on their phone, and test it? It should put you on 2g(x1) wireless.
Because it could just be EvDO itself, if we can rule out radio types, we can see if it is the system or if it is the radio.
For people that want a good ics camera with panorama working (For All Roms Too) try Camera ICS on the play store
Lol panorama is awesome
Sent from my LG-VM670 using Tapatalk 2 Beta-5
So...once again I'm back to AOKP. Flashed it, then superuser, then gapps, and now play store works and got titanium backup to restore all my apps. I heart radio works for those that want a working radio app. Still don't have service so can't check 3g yet...but I plan on using it as a daily for a while...can't wait till camera works. Also, what happened to the stock music player? Is it just gone in ICS? Can anyone suggest a simple music app...just something that I can shuffle all songs...similar to tye stock one?
Sent from my VM670 using Xparent Purple Tapatalk
I'm using the CM9 music player. works well
Original tread http://forum.xda-developers.com/showthread.php?t=1551747
Reactions: chellebelle
Status
destypage12
