ARCHIVED: [ROM][ALPHA] quattrimus ICS
Status
Not open for further replies.
I want to download alpha 8 i just wish 3g was fixed, any way for someone to pre install this? Im not about all that confusing stuff with build.prop and what not xD
Its simple!!! Hahaha if I'm illiterate with this I'm sure u can do. Try it bro. U will love it.
It's really not that confusing.
Flash Alpha 7 *NOT alpha 8* of CM9.
When it's all booted, open up Play and download ES File Explorer.
Press the Menu key, go into Settings, and check 'Root Explorer' and 'Mount system as r/o writable' (or something like that).
Tap 'Favorites' and click on the little phone icon with a / under it.
Tap the 'system' folder.
Tap 'build.prop' and it will ask you what to open it in, choose ES Note Editor.
Find the line that says "#ro.telephony.ril.v3=signalstrength,skipbrokendatacall,facilitylock,datacall,icccardstatus,1"
Delete the #
Press the Menu button, tap 'Save' and reboot your phone.
Done.
Delete the #
Done.
I tried it on alpha 8 aokp and it worked
Very clear, concise directions.
Btw, word wrap is a common option in text editors, typically under the view menu. It forces the text to display relative to the size of your window, as opposed to starting the next line when the enter key was pressed in the original file.
Sent from the BACKside of Tapatalk 2
You tell em! Lol :rolleyes:
Oooh, good to know. I only stressed Alpha 7 of CM9 because that's the only one I've tried and don't have the smarts to troubleshoot other builds, let alone that one really, lol.
3G and MMS fixes work on alpha 8 too. On that topic, has anyone found a tethering app that works? I need to get on the internet with my laptop. I've tried most of the big apps and even a few obscure ones.
Sent from my LG Optimus V running Quattrimus ICS, courtesy of tdm and his band of outlaws ;)
Good too know
Sent from my HTC_Flyer_P512_NA using Tapatalk
Did you try Wireless Tether for Root Users.
There is one but somewhere back in the pages I believe
Is there an mms fix?! Sorry im just so lost...
Sent from my LG-VM670 using Tapatalk 2 Beta-5
It's apns-conf.xml in /system/etc. Search "Virgin Mobile" after opening the file and change mcc to 311 and mnc to 490. For some strange reason, I had that memorized
Yes, along with Open Garden, FoxFi, Barnacle, and most of the other big names.
How do clear mms cache ? Can i boit in recovery and clear dalvik cach or cache?
Sent from my VM670 using Tapatalk 2 Beta-5
I changed wat you told me and then i cleared dalvik cache and still had no mms :(
I think you might be on a different page than me.
Lol.. i changed the apns-con.xml setting to the appropriate number then i cleared dalvik cache (wich was my desicion) and still had no mms
You changed it on your phone?
Status
shawnjosecrespo
