ARCHIVED: [ROM][ALPHA] quattrimus ICS
Status
Not open for further replies.
I working on a Camera fix because that is the only thing that is keeping me from releasing a my version of CM9, I am close now that I have found out what was wrong, time to just fix it. My next fix is the youtube fcs
It has something to do with the audio fix tdm had to use. It was working, as was Pandora but after the fixes it stopped
Originally Posted by JerryScript<br />
You'll need to edit the apns-conf.xml to reflect Virgin Mobile's values 311 490 ;)<br />
<br />
For anyone who wants to try:<br />
- use a root capable file manager, and copy the /system/etc/apns-conf.xml file to your PC (it's too large to edit on the phone)<br />
- open it with a good text editor (notepad may work, but I don't ever recommend notepad). <br />
- search for Virgin Mobile US, and change the mmc to 311 and mnc to 490. <br />
- copy it back to your phone,<br />
- clear cache in the MMS app,<br />
- reboot.<br />
<br />
Let us know if it works for you. ;)
When I open apns-conf.xml and get to the mentioned line, I found "mcc='200' mnc='053'"... did you make a typo, Jerry? Or do I need to change that value to "mmc"?
This is my Tapatalk 2 signature. Rockin' the app on my Nook Color running ICS 4.0.4, courtesy of Dalingrin, Fattire, and our other beloved XDA weenies (nemith, keyodi, arcee, hacdan, etc.)
Sorry about the late reply, it was a typo, it was supposed to be "mcc" & "mnc".
I tried this on alpha 7 and had no luck. I really want to know wat happens in alpha 8
Sent from my LG-VM670 using Tapatalk 2 Beta-5
With the 3G fix? Did you follow all steps exactly, including clearing the MMS cache? Sorry for being nit-picky, just making sure.
I don't wanna push u guys or anything but I REALLY would like to know when we'll get alpha 9? Before a certain date? And, wouldn't it be better to call it BETA 1 if it'll come with all the fixes?
Nobody knows, not even those working on it, nor can it be answered what will be fixed, or if it will be an alpha or beta release. It'll come when it comes, with what it comes with.
I updated the first post. Alpha9 by end of week. Beta when everything works minimally (which is not going to be alpha9 ... probably at least a couple months away).
Status
DonJrPlayz1234
