ARCHIVED: [ROM][ALPHA] quattrimus ICS
Status
Not open for further replies.
ICA is still in Alpha. NOTHING is fully functional iin this and Cold as Ice. There are no differences.
This made me laugh so loud I think my neighbors lights went on xD
Why would they not let you rent movies with a rooted phone?
Sorry for the off topicness. This is the only rom I've encountered this on because it's the only one that shows the movie tab in the play store that I have seen.
confirmed that current version's mms and 3g work! camera preview still doesnt work. having problems connecting to home wifi for some reason
Did clean installs of both CM9 and AOKP. WiFi appeared to set up but didn't give "reliable connection" in CM9 ; worked just fine in AOKP (same as the results I had with the alpha 8s).
The A9 is great, but the gps can't be turned off, and some settings can't change such as keyboard input, and the battery percentage thingy. No Swype at the moment :(
Also cannot change widget order in notification bar.
You have to go to language and keyboard and click the default tab and change it from there. That's the only workaround that I could find.
That didn't work, but at least the ICS keyboard is good enough to work sufficiently enough for my needs.
It didn't? That's weird. I've been using SwiftKey 3 beta since I figured it out. Swype works too. Which version are you using? Aokp or cm9?
I have to "forget" my wifi connection and readd after deep sleeps and reboots to get wifi going.
This only works half the time
*edit: turning off wifi, rebooting, and turning on wifi seems to work. Pretty sure someone already suggested it but here's a second.
Status
nickmeredith
