ARCHIVED: [ROM][ALPHA] quattrimus ICS
Status
Not open for further replies.
Alpha9 is released. It's not terribly well tested but I'm tossing it out there anyway. Let's see how it goes.
quattrimus-vm670-cm9-alpha9.zip
quattrimus-vm670-aokp-alpha9.zip
Changes:
Synced with sources a couple days ago.
Applied 3G fixes to both ROMs.
MMS fix should be applied to CM9, I don't think it stuck on AOKP.
USB storage works (tested on AOKP)
I was looking into bluetooth audio for some time today. Got some clues but no fixes yet.
AOSP is still not quite starting up. I took a bunch of stuff wholesale from AOKP (which in turn got it from CAF). I'm sorting out the wreckage but it shouldn't be long before it's running.
The 3g and mms fix Rom that robwalters72 put up worked for aokp stuck. And I can personally confirm that it works. Try looking into it TDM. Just friendly advice
Sent from my HTC_Flyer_P512_NA using Tapatalk
Can you post or link the fix? I cannot find it.
For those who want to check out Alpha8 AOKP with the MMS fix and the 3G fix already in the Zip, you can download it here.
quattrimus-vm670-aokp-alpha8-MMS-3G-Fix.zip
3G came right up for me when I went through the setup and I didn't even have to connect to wifi to set up my phone.
MMS sent correctly and also received correctly. Downloading happened automatically for me after a couple seconds.
Enjoy!
Rob
Here u go
Reactions: Badboytoast
Where can I get dsp manager and music player for the akop alpha 8?
Flashed alpha 9 of cm9 and everything that I need works perfectly except the camera preview but I'm ok with that! Thanks TDM! Wanting to try AOKP too so can I just flash the 3g/mms fix .zip mentioned above after flashing the ROM and reboot??
Does wifi work for u???
Sent from my LG-VM670 using Tapatalk 2 Beta-5
Keep in mind It's a whole rom in general not just a fix.
Reloaded theme works but a lil buggy as expected. Mainly the tabs for me. I had to toggle the theme on and off. Can't wait for that to be updated for the new build ;-)
So if I flash this after flashing alpha 9 will I still have alpha 9??
@TDM what will happen if the fix for mms gets put in again in the new build like it was manually.
Seems that CM9 breaks my over clock at 806mhz. Tdm can you look through the CPU module to see if there are any bugs?
It's the same kernel (well, not the same exact bits, but the same exact source that was compiled to get it). If you were stable at the same speed on previous CM9 builds, I don't know what to tell you ... other than I'm jealous you got 806 stable to start with. :p
Status
BrüZZi
