ARCHIVED: [ROM][ALPHA] quattrimus ICS
Status
Not open for further replies.
Running Cold as ice with VM fixes. Works great with camera preview
Sent from my VM670 using Tapatalk 2
Quit posting about cold as ice in this thread, this thread is for quattrimus. That's why this thread is so cluttered
Cant we use modified version of a Linux lib? I'm sure using the generics for the cheese webcam applications would do?
We just download the source and compile for ARM6
That actually sounds like a good idea. O-o
Sent from my Cybertronian QuattrOV using Tapatalk 2000 (Now With Teleka-Typing!!!!)
Totally possible :)
But it'd require a lot of work ':/
A good base to start at, Its better then getting the code from scratch from a reverse engineer.
Also, if the lib is going through Dalvik, cant we just dump the compiler calls and build from that?
Fine! :P
I'll do it..
If I have time ..
I have finals so I can't get started any soon...
-_- my computer is broken so I cant.. . (stupid hp and their design flaws being prone to overheating.) And my finals aren't until 3 weeks from now so I would have time.
Reactions: KeviiinS
How do you do wireless adb?
Connect your PC and your phone to the same Wi-Fi network.
On your phone, go to Settings > Developer Options and check 'ADB over network'
Open a command prompt and type in 'adb connect x.x.x.x' where x.x.x.x is the IP address of your phone on your network. (If you don't know this, go to Settings > Wi-Fi and tap on the network it is connected to, it will give you your IP address.)
Reactions: glarepate
is there anything i else flash? just the rom? i flashed once and i got some problems, so im gonna reflash. home button, wifi, etc.
What exactly you flash(as some people are floating between a7-a9)? How did you flash? How did you wipe(lol)? And exactly what problems you having?
Please go more in depth, or else nobody can help you. No offense in any way, just when you tell us what is going on in detail, we can help you better.
1 post with detail > 10 post of bits and pieces.
Sent from your mom's phone.
Quick question, does the terminal have to be running from a computer, or can you now adb with another device running a terminal in the same network?
Sent from my LG-VM670 running IHO MiRaGe using Tapatalk
I'm a little confused by your question, I'm sorry. Are you asking if you can send ADB commands from another phone instead of a computer? If so, I don't think so. You would have to have Java and the Android SDK installed on that device, which as far as I know doesn't exist for mobile platforms.
If I totally misunderstood your question feel free to tell me.
I get the question. The answer is no. You need to conect from the device you wanna have the connection with
Status
FahadsTech
