ARCHIVED: [ROM][ALPHA] quattrimus ICS
Status
Not open for further replies.
Making progress. thekraven pointed me at a CM patch that is still under review and hasn't been committed yet. I applied it and the camera comes up and takes pics. No preview yet though.
Just knowing you got BT audio working and you tube makes me ecstatic. Thanks for the hard work man.
TDM if I knew where you live I would give you a great big hug.:p
Sent from my VM670 using Tapatalk
As soon as I can get the camera fixed, I'll toss it out for testing. Then if everything pans out, it'll go beta.
@tdm, you are absolutely awesome! I would be happy to test the new version for you.
A thousand thanks for all your good work.
I gotta run right now so no alpha10 today. I'll try to get it out tomorrow. Here's where we stand:
Status...
CM code as of yesterday.
gapps 4/29.
Working...
I believe 3G and MMS are still working. Need to double check before release.
Camera is currently taking pics.
Bluetooth audio works. Haven't tested calls yet.
Youtube normal and HD work.
Not working...
Camera preview. Will be looking at this tomorrow.
The camcorder does not work and may never work.
Issues to look into...
Lots of log spam due to a specific kernel call one of the Adreno drivers is doing.
Had to copy one of thekraven's hardware libs because mine is making the screen yellow-ish.
Google Talk is FC'ing due to some resource image not being found.
Hey tdm, i'm getting very frequent crashes, is this common or just my phone is from a bad batch?
Wait, why won't camcorder ever work? /:
Mines actually doing the same. For some odd reason. It wouldn't do this with the stock rom or 2.3, so lets hope its just A9, that way next release it'll hopefully be fixed.
If it was the phone, we'd be screwed.
Status
2bit developer
