ARCHIVED: [ROM][ALPHA] quattrimus ICS
Status
Not open for further replies.
I'm looking forward to AOSP more than CM9 or AOKP
Sent from my LG-VM670 running IHO MiRaGe using Tapatalk
I fixed the AOKP browser.
AOSP is looking pretty good, pending browser testing (I think it had the same issue).
That leaves only MMS and bluetooth for audio calls to fix.
I'm planning to throw out an alpha10-pre1 in a couple hours in hopes that one of you enterprising folks can figure out the MMS issue. I just don't use it enough, nor have enough people to exchange MMS with for testing.
Now there's talks of camcorder working and even panorama!? Getting really excited for this ROM now. I just switched back to aokp from cold as ice and I'm using it as a daily driver. Love it. Thanks TDM.
I use MMS like mad, so ill be glad to help you out if u need it tdm :)
Btw is the Pre for AOSP? Or for each build?
I wish I had your brain for this tdm hahahaha ur the man.
On another note try contacting robwalters72 u believe his name his. He is the gentlemen that fixed mms and 3g on the last 2 builds.
Okay here's alpha10pre1:
quattrimus-vm670-aokp-alpha10pre1.zip md5: 65f8fa1b4e1a697c59e778542c39d55a
quattrimus-vm670-aosp40-alpha10pre1.zip md5: fee63d66bc5aedf4f153eaf0126293a7
quattrimus-vm670-cm9-alpha10pre1.zip md5: 5439f59474a7779e62d6e642e2964fa0
Still can't get MMS working but I've got a few clues. Let me know if anyone can figure it out.
This is code from about 4/29 for all three projects, gapps 4/29, the camera stuff from team HAL (lupohirp etc.), some kernel changes from Drew to support the camera, and some changes that thekraven pointed me at.
Huge thanks to team HAL, Drew, and thekraven for making this possible.
So hard to pick, which one do I want :p
Downloading cm9, will post results tomorrow as soon im done testing everything, (including battery life)
and again Thanks a lot for keeping the OV alive
EDIT 1: IT IS FAST, idk if it just me or this is WAY faster than a9, anyways, no crashes uptill now, a9 crashed very often (fingers crossed) :D and MMS working for me, had to turn off wifi to make it send tho
I'll be going with cm9.
Is the rooting problem fixed? Last time I flashed alpha 8, I lost root access xDD.
Using CM9
I'm going to put it like this tdm...
HOLY JESUS THIS ROM IS RUNNING SO F*CKING GOOD RIGHT NOW!!! TDM, JUST WOW DUDE! ITS RUNNING THIS GOOD IN AN ALPHA!!!!
I Owe you a brewery my friend!
Reactions: tdm
Status
BrüZZi
