ARCHIVED: [ROM][ALPHA] quattrimus ICS
Status
Not open for further replies.
So it looks like the big issue is phone service on aosp. Then there is possible cpu governor issues in the kernel.
The market 921 issue seems to be transient if you Google it. Also try clearing market data.
Drew and thekraven have a few more fixes that I'm going to try tomorrow also.
Thanks for all the feedback and don't forget to say which ROM you are running when posting. :)
So, got AOKP A.10 running amazing. After trying Alpha 8 AOKP I went back to Alpha 7 and now to Alpha 10 and hot damn, is there a MAJOR difference. Preview works flawlessly, AOKP ROM options work great, everything is running like a charm...
-Do you mind putting back the original Nexus BootAnim for AOKP please?
Reactions: Raul720 and tdm
I thought the unicorn animation was the intended official animation? You can always override it.
Eyep, for AOKP it is, my tablet also has it, but how do I over ride it? I don't want to disable it, simple replace it.
cm9 v10 so far everything working for me 3g data, wifi, camera, market, pandora,no fc's only issue ive had was when i tried to turn on the wifi hotspot blackscreened the phone had to remove battery to get it back but working very well so far.
Aokp is running flawlessly, no problems whatsoever.
Anyone know what the purpose of the swagger toggle button is? :p
I can't seem to notice any difference when it's on or off
Couldnt find the music player app in AOKP so I just installed CM9 music .
EVERYTHING IS AWESOME!!!!!!!!!!!!!!!!!!!!!!!!!!!! THANK YOU FOR BLUETOOTH!
EDIT: two random reboots
one i was installing beautiful widgets. and the other i was testing you tube....
Reactions: tdm and drm1992
What is the difference between cm9 and aokp? And which one is the preffered rom?
AOSP-Base Android 4.0, basically the "Stock" ICS.
CM9- Bunch of nice add ons and features, customization, added control.
AOKP-Like CM9 only with more customization features.
Preference is all personal, though I love AOKP best.
Reactions: radditz145
Semi-minor issue with CM9 alpha 10 pre release 1. Notification sounds and ring tones won't go through headphones if they're plugged in. They'll just play through the speaker.
Only bug I've had so far on CM9 A10 is that the web browser just doesn't want to render anything. Dolphin Browser HD works just fine though, so I'm gonna keep running it until either a fix release for the few random Play Store FC's comes out or I find a bigger bug. Amazing work, tdm.
Is YouTube videos really choppy on aokp for anyone else? A10 pre 1
Even in standard res videos are more like slide shows for me.
Besides that everything else accept phone is awesome. Oc'd to 806 interactivex, wifi, bluetooth, couldn't change lcd density in settings but I pulled it off manually in build.prop, will test gps tomorrow on my way to work. Phone fc's like before but you can still talk. And btw what in the heck is unicorn porn? I seen that asked a few pages back but no answer yet? Great work TDM
Reactions: tdm
I think this same issue was reported in the p500 xda thread. Not sure if it's by design or if they are working on a fix though.
Status
jeffnachatilo
