ARCHIVED: [ROM][ALPHA] quattrimus ICS
Status
Not open for further replies.
Re: [ROM][ALPHA] quattrimus CM9 (ICS)
Anybody else notice at the head of androidcentral forums, our people are the one's with the top posts and most liked? :)
Or does anyone know of a way I can remap said buttons manually?
Try this, all in recovery:
Install the ROM
Mount /system
adb pull /system/usr/keylayout/Generic.kl
edit the file to your liking
adb push Generic.kl /system/usr/keylayout/Generic.kl
Good luck! :)
Reactions: jimlikesmayo
with both other versions 3g was dead is it working herei reflashd back tobackside and 3g fire=s rifgght up
3G is working in TDM's versions of ICS. You must have flashed the ones without 3g. The 3g icon in ICS is on top of the Reception bar.
STILL KEEP IN MIND IT'S A ALPHA BUILD D:
Phone works, wifi works, music player works, had a random restart (but I guess it was because I didn't wait for the wallpaper to load), nice job so far guys. This really shouldn't be a alpha lol, more of a beta how it's acting. It's even faster than GB imo. Haven't tried mms, does that work?
Thanks again for the good work ^^
I had the 3g icon in leslie's build and I had no data.
TDM: do you want me to keep posting bugs I find in here? or somewhere else?
Yes please post bugs here for now. I'll find and setup a bug system soon.
Will definitely be trying this out over break. Looks freakin' sweet. I said this in the other thread but I'll say it again here: Fastest development EVER that I've seen for any device, period. It took them months to get various things working in ICS for the Nook Color, and here things are updated to working status by the hour. Amazing job everyone. This phone has been the best 150 bucks I've ever spent thanks to all you guys.
Tapatalkin it from my IHO CM7.2'd (Soon to be ICS), MIUI Themed Optimus V
Does Google Music work for anyone?
Edit:
Needs Flash player.
Hmm, I had a perfectly easy time flashing this ROM.
I am not getting 3G though, I made sure to flash the correct ROM or at least I thought so..
Build Date Thu Feb 16 14:30:57 CST 2012
Build Number IML74K
ok. actually I'm not sure if this is a bug or a 'feature'. I tried to power off while it was plugged into a USB port, but it rebooted. It powers off when not plugged in, but when I plug it in it powers back on. maybe at that level its not a rom thing.
Build Number IML74K
toggle airplane mode on, then off. then disable 'data enabled' and re-enable.
This is the good old chargerlogo thing. I haven't even put it into the build yet. But I'll put that on my todo-list.
3g does work guys and gals
Crap. I removed the custom usbstorage apk and forgot to test. Apparently the built-in usb storage functionality isn't working.
You can find it here. You should be able to install it with adb, eg. "adb install usbstorage.apk".
Seems to install fine with ES File Explorer also. :)
are you gonna use that as your "daily driver" for a while
I'm not going to. I will probably restore my nandroid in a few minutes. This is great for an alpha build and I have no doubt that it's going to be awesome after those bugs get fixed but our IHO CM7 ROMs are so complete that it's hard to leave them ;)
my copy of backside is bug/random reboot central
Status
reblkari666
