ARCHIVED: [ROM][ALPHA] quattrimus ICS
Status
Not open for further replies.
Re: [ROM][ALPHA] quattrimus CM9 (ICS)
Found a Voicemail bug. Calling voicemail sends calls VM, not your mailbox..
That was addressed in the previous thread, and will be corrected in an upcoming build. In the meantime, there's a setting you can change (not looking at my phone right now, so I'm not sure exactly where in settings), change the number from *86 to your own number to go straight to voicemail.
Ah I was going to say voicemail works fine for me, but that's because I dialed my number. There's a random contact that's called 'voice mail' with the VM number.
Still working on that custom Gapps. Anybody know if I should remove the videochat libs? Seems like something we wouldn't ever use, but you know gapps...
LeslieAnn figured out the bandaid for that until tdm takes care of it..
Voicemail fix...
Open the dialer, then hit the menu key, then select settings, then click "voicemail settings/settings for my carrier". Now click on the *86, now enter your phone number. Done.
Awesome, Thanks for the Voicemail "Band-Aid" I did find another Voicemail Issue that prompted that one.
The voicemail notification in the status bar will NOT go away. I have no messages in mailbox and I can't "swipe" it away like a normal notification.
Hoping to see a new build soon!
its about the same condition as the one for the triumph. almost everything working but the camera.
also, we have HDMI output that doesnt work in ICS yet either.
nice to see the OV get some ics love!!
im still the maintainer of 5 friends OVs so when this becomes good enough ill be installing it on all their phones.
I have something, google maps navigation doesn't work correctly. It will start normally, then as soon as it tells you the first thing to do (turn right for example) it says "unfortunately maps has closed" and gives the send error or exit thing. This isn't important that much just throwing it out there since I'm testing apps. Angry birds is next lol
Edit: also does any voice programs work yet all I see is "audio problem.
I'm gonna use this as my daily driver... as soon as i can get home and flash it. That way ill have fun and notice any problems. I think this is like the first time i don't wanna be in school (Taking Diesel Mechanics) just to flash something to my phone xD
Sent from my VM670 using Tapatalk
Portable Wi-Fi Hotspot
Try turning it on and it says 'Turning WiFi on' even though my WiFi is already on. My WiFi then turns off while it keeps saying 'Turning WiFi on'. I have to reboot to get WiFi back. If I try it with WiFi off to start with, same result.
Probably not supposed to work yet but thought I would throw it out there.
Reactions: Anonymo and dwappo
Same here.
Do we have to disable signature verification before flashing this ROM?
Found a bug. Speedtest app causes device to reboot (only reboots on 3g, wifi test works fine). You hit begin test, and after a few seconds the phone freezes and reboots.
I thought this was a problem with the phones radios, so i tested downlading a 3mb file over the 3g connection and it works fine. I can't get this to happen anywhere other than the speedtest app on 3g.
Not a super big problem but the keyboard does not go to the bottom of the screen in portrait, it make it alot smaller, other than that I like it,really good for an alpha
Re-flashing now! Thanks! Hey tdm you should add the modified Gapps to your OP too
You guys are finding bugs quick! Not much of a bug, but youtube wont play from the app... not sure about youtube in the browser but I did try some other videos and none would stream... videos played fine from my sd card though... cheers!
Also I found the Chrome Beta and tried to install with no luck just in case anyone was wondering about that.
And also a question: does ICS give us more leeway when it comes to Flash and making Flash work on our devices? I had Adobe Flash 11 modified for armv6 devices it worked okay but was still very choppy... any thoughts on that frontier?
Status
DonJrPlayz1234
