ARCHIVED: [ROM][ALPHA] quattrimus ICS
Status
Not open for further replies.
Is the exaggerated lag when listening to music normal?? I know it isn't, so can it be fixed in this ROM??
I know its not a priority at all but just take that it mind plz':)
CM9 overlooked to 748
I'm assuming that's a cm issue. I build cm9 from source with files tdm releases (patiently awaiting a push for alpha 10 ;) and I had the same issue on a build from yesterday.
I think using certain music players helps. I just installed Google Play Music and it seems to help.... I was using the CM Music Player before that...
I'm having some serious lag with Tapatalk and frequent anr's with it. How is it behaving for you guys? CM9, btw
Sent from my VM670 using Tapatalk 2
installed gapps separate and now play store shows everything i reinstalled with titanium backup as not installed. problem is new to 10, wasn't it 8 or 9.
then again maybe its a titanium backup problem.
Been testing CM9 all day. Force closes often when the cpu has any sort of stress. Hope it's worked out in the full release.
CM9 keyboard lags like a biatch all the time, both Alpha 7 and Alpha 10...
Even on 748, YT HQ doesnt work, but at least Standard works just fine.
Clear market data. Worked for me... Which version are you using?
Sent from my Cybertronian QuattrOV using Tapatalk 2000 (Now With Teleka-Typing!!!!)
Does anyone else have issues with hotmail and gmail not syncing? It worked fine for a while and they won't connect anymore. The gmail widget doesn't show any emails either.
CM9: I am using the Swype Beta keyboard, works like a charm. Tested YouTube, also works well. So far the only app that doesn't work on this is one called Beat the Traffic. It is a map-based app, so uses a lot of resource. Loads up and then crashes. Other than that, everything has worked well, overclocked to 480/806 as usual.
Anyone know of a way to disable or change the boot animation?
Yes how does one change the boot animation? I would like to change to the default ICS one :)
Status
kitlis
