ARCHIVED: [ROM][ALPHA] quattrimus ICS
Status
Not open for further replies.
I've noticed that when the CPU is stressed instead of fc'ing the phone just restarts a lot of the time. This is a problem I haven't seen in any ROMs up until now, I'm hoping that makes it easier to fix. Thanks so much this ROM rules!
Is anyone else having issues with battery on A10 AOKP? It seems im loosing a more battery than i normally do. Normally i would go to sleep and wake up with my phone at 80-ish when i get up on alpha 8 but i noticed today that i dropped 35-45 percent while the phone was doing nothing. 3g off, wi-fi off, bt off? Could it be that i was using Kickass last time and now im on InteractiveX?
I'm having a really bad issue in CM9
I can load pages in the browser and I can see them but when I'm on the Facebook app it shows a blank page.. I know it loaded because when I swipe down to refresh it shows the content... but then its blank again. It also happens to the Github client, I was trying to see a repo and it showed a blank page
Another random reboot this morning on AOKP. Unfortunately, these are happening when I'm not overclocked....on both Interactive and Smartass governers. So this doesn't look like an "overclock" issue.
yeah,in my experience it just reboots completely. even using the back button to back out of settings,etc. it does it.
Battery life has not been good for me on AOKP but its an alpha, no worries, I can carry a charger with me.
Sent from my VM670 using Tapatalk 2
This might actually be a governor issue.. I've noticed that this happens most when the phone has been off for a while and then turned back on so the governors might be having problems with bringing the CPU speed up. I'm trying performance today as it keeps your cpu speed at max so I set it at 480 and I will report back with my results. :)
Sent from my Cybertronian QuattrOV using Tapatalk 2000 (Now With Teleka-Typing!!!!)
A10Pre1 working great as daily, but voice search still stalls in several programs. Anyone else fighting this? Looking for workaround. Thanks
Great work TDM. Keep it up.
@tdm--- excellent work sir!... thanks for the upgrade... everything that i use on a daily basis works fairly smooth... gratsi!...
zv5- fyi
to the peeps having reboot issues... interactivex/480/600 has always been stable for me on quattrimus... doesnt seem to like smartassv2... apex launcher works nicely... doesnt like nova at all, and i dont care for trebuchet... deleted the bloat, installed the goods (imo), phone is good to go... :-)
Reactions: tdm
zv5- fyi
Tried it. Rebooted 3 times in 2 hours.... And I've definitely noticed that AOKP does not like SmartassV2. Nova works fine for me.... I've never used trebuchet. And yes the phone us good to go as a daily driver thanks tdm!!!!!
I've been using SavagedZen at max 825 mhz and min 480 mhz, no fc's so far.
Sent from my LG-VM670 running quattrimus CM9 alpha10 using Tapatalk
Any reboots? And I as well would like to know which one your running.
So I've done some extensive testing with all of the governors and I have come to the conclusion that ANY settings above 600 will cause the phone to reboot. The governors seem to be having a problem with with scaling the CPU speed up after scaling it down. AOKP btw.
This is exactly what I have been saying all along, the CPU module is buggy.
Reactions: Ryuk6666
Status
elijahchileshe12
