ARCHIVED: [ROM][ALPHA] quattrimus ICS
Status
Not open for further replies.
Is the lag on YouTube on AOKP fix?
Also is the Theme Chooser working:confused:
Sent from my Galaxy Nexus (not really) using Tapatalk 2
Oh that reminds me... is anyone good at making app icons and menu icons? I really suck at graphic design...
Im a Student in Visual communications and id love to help design something let me know if i can help in any way. it would be an honor. what kind of icons are you looking for
No theme chooser yet, sorry. I'm still working on the screen issue.
Don't apologize. I can use cold as ice for that anyway;) what screen problem are you referring too? Does it have something to do with the theme Chooser?
i had the issue where i wasnt getting any texts until i rebooted, and them i got them all. lol. another issue i have found is that im not getting any twitter updates either...have to manually check twitter now
A /cache and dalvik wipe is sufficient to upgrage CM9 to pre3, right? Also, the hosts file is still in Dos/Windows format. No biggie though. Thanks for adding DSP manager!
Adding DSP Manager is a plus to these ROMs. SRS Audio is also a good alternative. If only there was a way to make one of these compatible with streaming apps, such as Pandora. Maybe one day it will happen, like with IHO.
Quick question, is it possible to rename the zip without coming upon any problems? I can never tell what zip im highlighting when installing zips.
Reactions: suku92
Definitely more stable, it seems. I stress tested it via loading a Tapatalk thread with a ton of pictures, and it did end up force closing, but loaded a great portion of it before doing so, as opposed to before when even a couple of pictures would kill it. I don't ever expect it to run 100% perfect, as it's been stated many times how "heavy" ICS is, there are bound to be memory issues, but I'll be damned if this isn't any bit as good of a daily driver as IHO is. (obviously YMMV, just sharing my findings so far.)
Does this update fix the speaker phone? I also got play store fc on cm9 but a few hiccups is more than an easy trade for the awesomeness this is giving me. Also with this update I am back to stable at 806 -480.
Confirming Play Store FC's on CM9. Guess I spoke too soon, lol. :D
edit -- If it's relevant, i should point out that I am using a modded version of the Play Store and GoogleServicesFramework.apk because of my pixel density, so that could also be the culprit in my case. I only said something because others were reporting the FC's this time around.
Status
dumpsterrentals97
