ARCHIVED: [ROM][ALPHA] quattrimus ICS
Status
Not open for further replies.
Just noticed the post from thaunknownartist regarding him being pushed off of this site. That sucks b/c he put out good stuff. I'm posting this here to simply say don't ever leave us tdm! While thaunknownartist will be missed I can continue avoiding buying a new phone without his work (even though it was good stuff). However, if tdm stops developing I'll have to buy a new phone. So please, don't ever leave us!
My YouTube is still choppy. Has anyone fixed this?
It runs well under the cm9 build. HQ is unwatchable tho.
The aokp is a freaking slide show either way :(
kakapopo, download density modder pro from the market and you can change the size.
sent from my device using XPB ICS Tapatalk 2
Can someone recommend a decent clock to use with this rom?
Preferably something consistent with the ics interface.
Noticed a bug: if phone is awakened from sleep, time displayed is not correct. It takes a few seconds(15-30s) after being woken to display the correct time. This is regardless of whether time is set to sync with the network or not.
Thanks for all the hard work!
I had the same problem with Harmonia after switching back from cm9. I think it was because between the two images I had massively different apps...probably screws with Google's manifest of the apps I have installed :D
Yeah, that's been known for a while
Hey even if its backed up and lets say the encryption goes 50% i couldnt restore cause its en encrypted......
also i keep getting apps closing like " The Play Market Just Closed " Is this normal since its in alpha?
Okay im going to try the encryption
OKay i clicked encrypt and all it shows is the green android guy like coming apart i think its the encrpytion droid and it doesnt do anything
What do i do...
For anyone that likes a little more customization, I flashed Reloaded and changed my status bar up a little bit. So far there playing nice together. By the way, no fcs or reboots so far today :D The link for Reloaded is on xda and supposedly works on all CM9 roms.
OV CM9 quattrimus ICS
Reactions: Badboytoast
What do i do...
Don't encrypt. It says it takes quite a while so I wouldn't expect it to be done in a minute or two, probably more like an hour.
Sent from my LS670 using Tapatalk 2
I finally figured out why my phone would lock up. I have to drop down to 480mhz as my max cpu speed instead of the stock 600mhz. That's odd because I can safely overclock on the Gingerbread ROMs though I keep it at 600mhz anyways on them.
Status
yanis
