ARCHIVED: [ROM][ALPHA] quattrimus ICS
Status
Not open for further replies.
pretty snappy on boot,but fc:s came on strong ss soon as i tried to enter settings. first reboot was in drop down to adjust stats...reboot. then on reboot i attempted to enter settings to adjust cpu rate,it froze for about 20 seconds with what sounded like a squelching noise then rebooted. after that it was time to delete. check on it next release.
with what version? CM9?
Hey tdm, I don't know if this will help but thekraven almost has his camcorder working, (his alpha 11a) someone said that it shows a preview and everything and tries to record, it just crashes after you stop recording. Love the new build!!!!
Sent from my Cybertronian QuattrOV using Tapatalk 2000 (Now With Teleka-Typing!!!!)
Mines fully records without crashing when I use Camera ICS, only panorama doesn't work. I'm currently running CAI a10G and I don't get any crashes whatsoever. I'm gonna try out AOKP tonight. Has anyone tried out all three of the quattrimus updates yet? I'm getting great battery life on CAI, how's the battery in AOKP for anyone that's using it?
Sent from my LG-E739 using Tapatalk 2
I built a new CM9 ROM and put the delta up. The updater fetched it fine and then ran out of memory applying the patch. Apparently the java rdiff implementation is not very memory friendly.
Got the memory issue fixed. So here's how it works:
I publish a manifest that contains a ROM list. Each ROM description has an URL, filename, filesize, and md5sum. It may optionally contain the name of a "base" ROM and the description of a "patch" file that can be applied.
I successfully downloaded a base ROM from mediafire (cm9 a10pre1 in this case). Then I uploaded a patch file to turn it into my next update (cm9 a10pre4 in this case). The updater noticed that it had a10pre1, so it downloaded and applied the patch. Yay!
How much of a savings is this? Well, in my test, the patch file is 34mb and the full ROM is 96mb. So that saved 62mb (almost 2/3) of the data. I expect that to be fairly typical for quattrimus, though the -pre updates within an alpha release are likely to be smaller. For example, cm9 a10pre1 to cm9 a10pre3 is 11mb.
Now, I'm on to making some context menu icons and continuing to hack up my recovery-free installer. :D
Oh yeah, and back on topic, I'm also fixing some more issues for a10pre4. I've got the hosts file line endings fixed and adb-over-network for aokp done. I'm also investigating "su" on aosp and some other things. And trying to get the latest cm9 code to run, of course.
I just had a reboot when I hung up the phone. I pressed the red end call button and while my finger was still on the screen, the boot animation was suddenly starting.
I was oc'd at 787/320 on inter-x. I bumped it down and I'll monitor to see what's going on. It's probably just my setting, but wanted to mention it.
Rob
Reactions: Badboytoast
If there is one thing that should be obvious by now, it is that you can't define which is more stable. It's all YMMV. Make a backup, flash it, and see for yourself.
ima get killed for asking but is this as stable as CAI yet? i reailly dont like goSMS for MMS
as stable? ive tried both and both force close like ms-dos infected with the cap'n crunch virus lol...i guess stable is all in how you see it lol. :D
I can't wait for the force closing issue to be fixed! I'm on CM9 a10p1 and it drives me nuts.
A little noob question as well: Which build is most stable, CM9, AOSP, or AOKP?
You seem to be a special case. Nobody has had the volumes of issues you do with these ROMs. *shrug*
Pre3 is the latest. CM9 is "technically" the most stable, as AOKP and AOSP need code from CM9 to force compatibility with our type of processor.
Reactions: Nico72
Is there a workaround for the 'package not valid' error yet?
Check that your /cache and /data partitions have plenty of space. If they do, I don't really know what it could be. If they don't, try clearing some space and use an sd-ext partition.
Status
BrüZZi
