ARCHIVED: [ROM][ALPHA] quattrimus ICS
Status
Not open for further replies.
I hear people talking about the Gmail going blank and I think it has the same effect as possibly my Instagram sometimes not loading correctly. After a reboot, it works fine. My laptop is usually right next to me so I'm not to worried about the Gmail working at all times, it helps me disconnect from the virtual world of emails. Also, I expect things to be glitchy with a ROM that isn't quite 100% and is just that, an after market ROM. Try clearing your cache, force stop your app and then reboot and open your app back up. Works for me. Love you all!
Happens to me with Gmail and Facebook. Copy them to /system/app and change permissions to rwxrwxrwx and reboot. Works for me.
Reactions: Ilovefarts
What do you need to copy when referring "copy them to..."? Do I need to go into my file manager? Just curious, thanks buddy
I guess I need help on how to do this. I thought I knew, but I'm drawing a blank
I use adb, though it may also be possible to use a file manager that gives root access. Maybe look here for tips on remounting, and here for copying the files over.
Sorry, I was like 3/4 asleep when I posted that, I guess I could have been more specific. lol
Yeah, I tried brewing coffee without grinding it and then complained that I hadn't had my coffee yet. Go figure.
By the way, thanks man. This forum has been super helpful and hope that I've been able to lend a helping hand to someone. Pay it forward.
My phone still freezes itself and reboots randomly no matter what setting I put the CPU at.
same here...specifically when i access the dialer.
but also i've noticed that the new version of friendcaster wants wifi on ALL THE TIME otherwise it will cause random reboots.
What i did to help that out was did a sd-ext partion and in like almost two days only had one reboot. And my cpu is like: 480min/787max with SmartassV2
I was having ROM flashing withdrawal. I need an update fix like a crackhead need crack! Had to root my girlfriends optimus q and throw a ROM on it to hold me over.:eek:
I need an update like Mick Jagger needed smack in the 80's.
Woah guys no update statements. Think of it this way, he's probably working really hard right now to work out a lot of the kinks to give us an amazing rom. So just be patient you we'll receive an amazing update just like always. ;) thanks tdm for taking your time on this project and not letting people get to you :)
Sent from my Cybertronian QuattrOV using Tapatalk 2000 (Now With Teleka-Typing!!!!)
when i reboot my phone the screen just stays black it dosent give me the clockwork options.ive let it stay like that for 5 to 10 minutes to see if it just takes a while to come up but nothing come up. can anyone help me with this please please. i rooted it with gingerbreak.by the way i have the lg optimus v
I was referring to my personal need for some thing to flash. If I was gonna ask for a timetable for an update I would have wrote something like this:
ETA?ETA?ETA?ETA?ETA?ETA?
...but I didn't now did I. :D
I had this problem too. I just downloaded a mother recovery and the flash image GUI apk and flashed the new recovery through the app. Actually someone posted a link to a touch recovery a few pages back, try that. Wen u use flash image GUI make sure u click to delete cache n dalvik cache
For anyone with phone fc problems, is your lcd density default or have you changed it? I had the same problem and come to find out it was bc I had lcd density set to 130. Replacing phone.apk with ldpi compatible phone.apk fixed my fc's. Just figured I'd share my knowledge.
Tell me more.
Changing it lcd density I kinda like changing your screen res on a PC. It allows you to fit more on ur screen and it is a good solution for people like us with smaller mdpi screens as it makes the phone feel bigger than it is. There are 4 lines in the build.prop you have to edit. All titled lcd density and they are in different places. Lowering the number results in a higher number of pixels per inch thus a bigger screen size. I have mine set to 130. Default is 160 for mdpi phones like the ov.
Status
redmercer
