ARCHIVED: [ROM][ALPHA] quattrimus ICS
Status
Not open for further replies.
There's an strange silence coming from tdm..... he must be hard at work in his secret lair.....
hes adding a sweet sweet chocolate coating to his ice cream samich rom. lol...carry on people!! :screwy:
I noticed that doing sd-ext partion really helps out alot!
AOKP, I just tried it out and compared it to CM9. For me, AOKP has to much going on. And with the way my brain works, I wanted simplicity. CM9 is perfect. It has plenty of customization to go with a rather bare to the bones ROM. That's just my take. Don't get me wrong, AOKP has unicorns and you should know, I think they are kick a**
My thoughts exactly! Except I didn't like the unicorns.... it made it not feel like true ICS
Reactions: pbailey212
I didn't mean to thank, accidently hit the button. (No offense)
I've noticed recently that when i get a gmail notification, when I go to check it the moment i scroll down the message goes blank...
Anyone else having this issue?
Same here. Doesn't happened for all messages. Usually just notifications about private messages from here and xda, but it only happens most of the time. Weird
yes i am also seeing this.
i am running the blacked out gmail app tho...i kinda thought that was the culprit.
are you running stock gmail???
Having issues with yahoo mail app closing randomly not a big deal to me but just hadn't seen anything on it I love this rom I use it as my everyday system and have done so for a few week now can't wait till its final
I have an issue with the device always freezing and rebooting itself. Maybe its cause i have my CPU at 128 min and 864 max...but it was stable when running thaunknownartest's ROM....i don't know if this setting is what is causing the random reboots or its just cause the rom is unstable lol
First change your oc settings. That's whats causing the reboots. Your stressing the cpu too hard, try 480 min 806 max interactive x. (seems to work for most people) look up LeslieAnn's overclock guide its a huge help and can get your cpu to run fast and efficient and it can also save you some battery life. :)
Sent from my Cybertronian QuattrOV using Tapatalk 2000 (Now With Teleka-Typing!!!!)
External sd card, I reckon.
Actually no, it's a second partition on the SD card. The first partition on the card issue mounted as /sdcard, the second is mounted as /sd-ext. Typically used for 2sd scripts like Link2sd or Magpie.
Also, the ext means extended, as in the first partition is primary, and the second is extended.
This space intentionally left blank.
Posted the solution AGAIN in the ov CAI thread here. Please read the page you post on before asking questions, I had just posted the app that works,literally five posts before your question.
Status
fidsomedia
