ARCHIVED: [ROM][ALPHA] quattrimus ICS
Status
Not open for further replies.
Re: [ROM][ALPHA] quattrimus CM9 (ICS)
Thanks!
So the first two commits change existing files, and the third commit is a new file? And I assume the new file lives at /system/lib/bluez-plugin/audio.so based on the commit path, correct?
I flashed the alpha 5 and when I checked the kernel version under about phone, it still says iScream kernel. How do I change it back? >_<
I was playing with the iscream kernel and accidentally left it in the build yesterday. Sorry. New build today will have gingerkernel again.
How can I tell the difference between a quattrimus bug and a CM9 bug?
Only CM9 bugs (like the battery percentage bug?) go on github?
It's not easy to know for sure. If you don't know or just want to enter a bug to keep track of it so it doesn't get forgotten, that's fine.
What I meant to point out is that I'm focusing on getting hardware working first (mainly camera, mic routing, and hardware opengl acceleration).
Not to be a bother, but how long exactly till hardware acceleration is fixed?
Also, 3G problems, it connects, then randomly disconnects, then connects and repeats.
Any fix?
Any fix?
Any fix?
I think at least part of the fix is in the kernel. It will probably be next week before I can get a good VM670 kernel with all of the proper drivers.
I know 3G is a bit finicky but I don't know what can be done about it at the moment, sorry.
Reactions: Masema
is there any fix for the UMS popping up over and over. The USB Mass Storage thing, i no it isn't a priority but i was just wondering, and what exactly does this mic fix do (fix voice search?)
You can remove /system/app/usbstorage.apk if you don't use it.
Thanks!
Correct.
@Jerry: I've looked up some instances in where people deleted databases from: data/data/com.android.providers.telephony and it fixed MMS for them. I can't confirm though, as I just lost service about an hour ago (stupid credit card :P)
No update for today. mediafire.com is refusing to work with my browser at the moment.
All I had for the day was to revert to gingerkernel and apply the mic fix anyway, since I'm focusing on the kernel and getting my files uploaded to github.
Reactions: Masema
This may be a dumb question but does the Mic fix fix the headset issue?
Correct.
Not without changes to CdmaSMSDispatcher, all they will get is 999999999 and unicode.
Working on the changes now. ;)
Hehe first time I saw 9999999999 I thought I was going crazy or getting spammed or hacked or my phone was self destructing... a number of other things ran through my head as possibilities as well:p
Sent from my Optimistic Optimus
I thought someone actually texted me that, LOL.
Status
yanis
