ARCHIVED: [ROM][ALPHA] quattrimus ICS
Status
Not open for further replies.
I upgraded to ZV9 and this rom works perfect now
Hmm, I guess that's more of a reason for me to upgrade to it now.. Even though I'll loose free bootloader access.
(Question: What works perfect now? Stability, freezing, reboots, etc?)
Anyone know if there are any problems with Link2SD, switching between this ROM and BACKside? Does rebuilding the links work OK, or will I have to wipe the Link2SD partition on my card when I switch ROMs?
Since I upgraded to ZV9 (I'm using latest Alpha of AOKP), I get far fewer reboots: I used to have 10+ per day, now less than half that. There's still some general instability?I am using an alpha OS, after all?but I'm no longer so aggravated that I think of going back to GB several times a day. In fact, I'd say that ICS is nearly as stable for me as GB ever was. I don't know if that qualifies as perfect, but it's good enough for me.
In short, though the ZV9 upgrade was a little bit of a hassle, it went smoothly enough, with nandroid backups, and ultimately seems to have made my installation of Quattrimus AOKP run more smoothly and with better stability.
(Besides, it was fun to run a stock, un-rooted ROM for three or four minutes. Hadn't seen that in awhile!)
Link2sd kept force closing all of my apps on alpha 10. You don't need it though, tdm put an app2sd script in the rom
Sent from my VM670 using Tapatalk
Reactions: inceyet
:D GANNON yo good to see ya back bruh and to see you teaming up with tdm :D hit me up if needed
I upgraded to ZV9, got no reboots, better performance. Nothing special.
Flashed update
Booted
Rooted
Wiped
Flashed
Booted
Tested
Had no problems. :D
I don't know if your planning to use the linaro toolchain anytime soon, but in case you didn't know, i have been reading that anything higher than optimization 2 breaks Netflix and some other video services for the time being
sent from my Nokia 5110
i installed aopk and i get youtube video frames skips but you can still hear audio fine.. has this been fixed or is it still a problem? thank you
YouTube and even Adobe Flash won't be fixed until we get those OpenMax codecs we desperately need for hardware acceleration on our processor. :/
Reactions: brotherswing
YouTube works fine on cold as ice though. And they don't have the codacs.
for the last time. THIS IS NOT THE COLD AS ICE THREAD!!!!! Im sure tdm already knows what works on cai from the hundreds of other posts about it.
Im done ranting now :p
Now you guys are starting to understand me! :)
Btw, is there stuff missing in the kernel for ZV4/5? It seems to work perfect on ZV9.
There could be, but idk. What baseband are you running tdm?
Status
omgitsjoshitos
