ARCHIVED: [ROM][ALPHA] quattrimus ICS
Status
Not open for further replies.
78MB still free. The two apps I still need only add up to roughly 30MB once installed.
Moving a few to external helps. Some of us have problems around the 100mb Mark for some reason. If you have a big one like Facebook on your phone, move it and if be willing to bet the error will go away. I've had it happen a few times
Anyone else noticed that Beta1Pre3 seems to do its rebooting on 3G? Don't really notice many problems on wifi, but as soon as I turn on or off 3G it seems to go crazy
I seem to have plenty of storage space even after installing a ton of apps, but I'm getting "insufficient space" and "package file is invalid" errors. Also, I can't restore any more apps with TB.
Code:
Filesystem             Size   Used   Free   Blksize
/dev                   209M    48K   209M   4096
/mnt/asec              209M     0K   209M   4096
/mnt/obb               209M     0K   209M   4096
/system                164M   151M    12M   4096
/data                  178M   134M    44M   4096
/cache                 110M     1M   108M   4096
/sd-ext                457M   432M    24M   1024
/data/dalvik-cache     457M   432M    24M   1024
/data/app              457M   432M    24M   1024
/mnt/sdcard              3G     1G     2G   4096
/mnt/secure/asec         3G     1G     2G   4096
/mnt/asec/com.google.android.diskusage-1     2M   160K     1M   4096
/mnt/asec/org.transdroid.search-1     2M    52K     1M   4096
/mnt/asec/com.adobe.flashplayer-1    14M    12M     1M   4096
/mnt/asec/com.citizen12.warheads.full-1    17M    15M     1M   4096
/mnt/asec/mobi.megeek.DesktopToggles-1     2M   116K     1M   4096
I just flashed from mirage and I can't get anything to download from the Google Play Store. I've tried on three different Wifi networks and 3G and haven't been able to find any solutions. I've clean installed 4 separate times using different gapps files and no luck. Help!
It shouldn't be a big issue dirty flashing to an existing ROM to update. I never had any problems doing that. But if you're flashing a different ROM, you need to wipe data too.
"ROM list updated"
and now i have zero roms listed in romkeeper...
anybody else seeing this?
Yeah I've got that a couple times when I had bad reception, typically if go somewhere with better signal it reloads the list.
I sometimes get that message and nothing had changed lol
Yeah I've got y a couple times when I had bad reception, typically if go somewhere with better signal it reloads the list.
I'm seeing it right now. Currently on WiFi
I had some issues signing into Google, so im using gapps that Bobzhome has in his cm9. There's two options, I'm using the custom one that's smaller with no problem
Ever had issues with syncing?
Sometimes I could have 3 bars and browse the web and all, but when I try to sync Gmail, it says No connection.
I'm having a real brain fart day with this phone. Which files house trebuchet and all the wallpapers?
Status
Sipoko
