ARCHIVED: [ROM][ALPHA] quattrimus ICS
Status
Not open for further replies.
Dev folks,
Just switched from the Optimus S Cold As Ice build to quattrimus; looking good so far! Thanks for all the hard work.
Question, though: What is the kernel repo you all are using for the CM9-based quattrimus build? I've been trying to setup IPsec/L2TP and PPTP vpns, but I think the kernel is missing some modules. I'm more than willing/able to compile my own kernel, I just want to make sure I'm using the "right" one, minimizing the changes from official quattrimus.
From what I can tell, some essential ppp kernel stuff is missing (ppp,pppox...) given the errors I'm seeing. If that stuff is built in already, though, it looks like I'll be troubleshooting some more :(
Reactions: tdm
Does anyone know any tips or tricks to make this from stable!?:) kernel tweaks or scripts.. something?:)
Install it, run it, capture logcat of errors and post them and bugs.
That will help @tdm move out of late alpha into beta. In a few months, beta will progress, and then release candidates will come, until finally, Final Release.
This is a process that happens over time. If you want quick fixes, not gonna happen, Find a stable ROM from some GB choices, since the ICS versions are still in early development.
Reactions: mlson and cmerlyn
Sorry to trouble you again, tdm, what toolchain are you using? I know some have moved to the linaro toolchain, but if you have a specific version...
Thanks again,
Has anyone found a fix for the white screen on Facebook and Gmail
Reactions: tdm and brgavino
I looked around, only found one comment that seemed relative to mine. Is the in-call audio really low? I'm finding it kinda hard to hear people when I call them.
Some have said to check "force gpu rendering" and others said to clear the app's data. I did both at the same time and it hasn't been an issue for me since, though I couldn't say which one worked.
Rob
Reactions: Badboytoast
Thanks again,
The default. Linaro is not quite stable.
Mines fine. Idk if the zv9 update would help you or not. I didn't do it because I've heard so much bad things about it. But personally mine is alright.
Did you try clearing data of the particular app in the app settings?
I have tried clearing data.
Rob
Where do I do the force gpu rendering? Never heard of that.
My CPU spy
I also switched wifi tethers default to the thunderc which had softap instead of just wext(ad-hoc) although it says its working I can't seem to get a AP on my laptop or ps3. Logcat is also throwing a lot of errors about it
Status
MichaelCrusan
