ARCHIVED: [ROM][ALPHA] quattrimus ICS
Status
Not open for further replies.
Ok guys. I got Paranoid Android booted! The whole Tablet UI and everything is there!
Bugs so far: 2 Setting options don't work. Task bar isn't at the bottom due to Paranoid Setting being broken. Keyboard is wonky, gonna fix. MMS, I don't really know, need testers.
Screenshots: Click to view quoted image
Even the browser!
I would love to test this could you please post a link to your thread or link to download the rom thanks
Even the browser!
I will test
I don't care who u are :p this is an awesome song :) http://www.youtube.com/watch?v=dxytyRy-O1k&feature=youtube_gdata_player
anyone getting a prompt that states "clock has unexpectedly stopped working" when they boot up? i get the prompt but the clock is indeed working correctly.
My clock randomly won't work right. I'll turn my screen off say at 130 and I could wait an hour, turn my screen back on and it'll still say 130 even tho its 230. Mostly after phone calls.it'll reset in a couple minutes to the right time. Just confuses you for a sec
Never had a clock FC. Wonder what's thats about.
Clock lag is still there, soon to be gone. TheKraven fixed it, and then it came back. So shouldn't be to long. :)
Even the browser!
shoot me a link with your changes on github and ill take a crack at fixing some things
yeah, haven't experienced that. just the prompt that will randomly come up after boot. i just click okay and all is fine after that.
Try a new cable/ battery. Does it charge with another rom?
Edit: oh never mind it does work with another rom
Sent from my LG-LS670 using Android Central Forums
I've updated my Original Post #7384, where I've report on additional "cannot power off" issues and done more troubleshooting, including trying with different cables and the Harmonia 2.08 ROM.
/Thanks
First, I'd install the new Cannibal Open Touch Recovery. Xionia is known to not wipe some partitions well. I bet you have something left over conflicting with Quattrimus.
http://forums.androidcentral.com/op...en-touch-v1-2-latest-update-06-24-2012-a.html
Then wipe /system, cache, data a couple times, then flash Quattrimus twice in a row, then gapps twice in a row, both before reboot. Also, clear cache and dalvik again befor first boot.
I've updated my Original Post #7384, where I've report on additional "cannot power off" issues and done more troubleshooting, including trying with the Cannibal Open Touch v1.2 Recovery with and without multiple "full wipes".
/Thanks
@TDM
I've been using Cold as Ice alpha 15F, and wanted to report the BT turning off issue is gone, I can turn it on, talk, call, hangup. and then I turn BT off and no reboot.
Maybe you want to look into it
Thanks for doing an amazing job!
Doing what I always do. o-o
I learned from Gannon. I'm gonna make a thread in about an hour when I work out some minor bugs.
Major help needed here!
Rom is unrooted! How can I pre root it?
Great to hear I honestly can't wait to test it be sure to post a link ;)
Ask tdm, I think the same thing happened to him with aosp.. I believe he fixed it, so he should know....
Also can't wait to try it out :)
G-T-R & Quattrimus CM9 Nuff' said.
(Also, sent from my LG-VM670 using Tapatalk 2.)
Reactions: jnow2
You can also link to a flashable superuser zip
I misremembered the way I make those images on my own computers. If you are in a Linux environment, you should be able to open it with tar, as it's probably a tar archive with gzip, bzip2, or xz compression. Maybe Android is different in this regard than what I use, though.
Use dsixda kitchen
Status
BrüZZi
