ARCHIVED: [ROM][ALPHA] quattrimus ICS
Status
Not open for further replies.
Haven't been on this thread una while but can someone explain what is nightlies?
Sent from my HTC_Flyer_P512_NA using Tapatalk
Still having charging issues (=no charging) on my VM670. Tried with the latest night builds too. Which Android/Linux processes are handling the battery charging? Which processes (or events; how?) can I look for to make sure they're up and running?
I am having the same issue so if you find a solution please post it on here. I will do the same.
VS660 has service, 3G (with roaming enabled) and it's kicking butt. This is the best day since that shifty little sales fella manipulated me in to taking this device out of the store. So the only thing I can see that needs fixing is the obvious button issue. Other than that, I'll be spending a good amount of the evening putting this thing through every freakin' test I can.
All Hail TDM!
Reactions: Powmining and tdm
To compare dmesg output, boot your phone, plug it into a computer, and run "adb shell dmesg > dmesg.out" (or however you do that on windows).
The button mapping fix should be in the next nightly.
I suspect the button lights not working are related to the kernel. The VS660 kernel is somewhat different, and I've not pulled in any VS660 specific changes yet.
I'll be looking into 3G and the roaming indicator over the next few days.
ok since goo is down does anyone have the latest nightlie for vm670?
I'm looking for the vs660 nightly as well. The vmroms site only has the pre3 build on it.
My nightly zip from 6/29 is reading corrupted for some reason :/
I can just as well wait for another nightly tommorrow... the radio fix is just so exciting~
Looks like AOKP is passable. I'm going to enable AOKP nightlies and see what happens.
Also, since goo.im is apparently unstable at the moment, I'm going to be pushing nightlies to the other two mirrors as well.
vmroms.com/~vmstorage/quattrimus/
tdm.simplydev.com/roms/quattrimus/
Cant wait to try out the new aokp :D so stoked. :D
G-T-R & Quattrimus CM9 Nuff' said.
(Also, sent from my LG-VM670 using Tapatalk 2.)
TDM -How do I compare the two kernel dmesg output?
Andrew Nelson-- When I plug the phone in the computer nothing at all happens. It does not sense anything is even plugged into the usb port.
It may be time for you to buy a new charger/USB cable.
If you are still using the stock USB charging cable, they are faulty and have a very limited life span that varies from only a couple weeks, to a couple months.
Visit your local electronics store, and pick up a new charger.
sent from my un-dead sammich
the 3g worked fine, it might be that i enabled roaming in the settings though that it worked.
Oh, and now that aokp is building, aosp should be relatively easy to get going. I'm curious how many people really plan to use it for a daily driver.... anyone?
If wifi, google play, and data all works, I will :D
VS660 on rilfix2.zip
Battery
Under battery usage, it's showing Display taking up 90%. I've never seen this before on Android. Could be something to look into. It did seem to drain rather fast after flashing the zip. I went from 49% to 9% in less than an hour.
Camera
Camera crashes on attempt to use Panorama mode. Not a big deal, but a note.
Homescreen Widgets
I've been using Fancy Widgets for my clock and weather for awhile, and this seems to be the first time I haven't been able to resize and center the widget. This might be a ICS thing, not sure. Adjusted grid size to 5 and then 6, but still no centering.
Play Store
Upon the first boot, I had Play Store working for a bit, but after about 20 minutes it disappeared from the apps drawer and when I clicked the top right icon for the store, it gave me a message along the lines of "the Play Store is not available." Not verbatim. A reboot fixed this. Haven't seen it since/
Chrome
Obviously, Chrome would be awesome, but I guess it still recognizes this as an incompatible device. I was hoping ICS would be the only requirement. I guess the hardware just doesn't cut it. Anyone with an update on porting Chrome to this device would be nearly as awesome as TDM. However, I have noticed that syncing the browser is working. It's syncing my account and bookmarks with Chrome, apparently. Freaking awesome.
Button Remapper doesn't seem to give a s--- what I want it to do. Maybe I'm dumb and haven't figured it out yet.
Overall, this ROM is awesome so far. Can't wait for updates now.
Reactions: tdm
I'd like to see it. I had an AOSP ROM on my Fire that I liked, just not much experience with AOSP.
I'd like to play around with it, see what it's like. I may give it a go!
Also, changelog for 7/2 nightly says "no changes"....do nightlies get pushed everyday even if no changes? In other words I don't really need to flash this one do I?
Sent from my LG-LS670 using Android Central Forums
Chrome
That's because Chrome only works on Armv7 processors- since our phone's are Armv6, it won't work :(
Reactions: lesheifner
Can someone who has posted themes on this thread PM me? I have a question about inverted apps but I don't want to clog tdm's thread....thanks!
Status
reblkari666
