ARCHIVED: [ROM][ALPHA] quattrimus ICS
Status
Not open for further replies.
Temple Run was originally only armv7, xda ported it to work on armv6...somehow..same thing with flash player....
I know. Last I looked, a couple weeks ago, everywhere I looked for a cracked Chrome for armv6, it said it wasn't possible. If you happen to find one, let us know!
Oh, and now that aokp is building, aosp should be relatively easy to get going. I'm curious how many people really plan to use it for a daily driver.... anyone?
I'm down to try aokp again.
VS660 on rilfix2.zip
Button Remapper doesn't seem to give a s--- what I want it to do. Maybe I'm dumb and haven't figured it out yet.
Overall, this ROM is awesome so far. Can't wait for updates now.
Yeah, I couldn't figure that out either. So I used a text editor to change it. Open up /system/usr/keylayout/thunderc_keypad.kl with a text editor and switch the numbers 139 and 102. fixed! then reboot.
Reactions: tdm and lesheifner
VS660
So here are some new issues, I think.
1. I install apps, and they disappear after reboot. Icons remain on the homescreen.
2. Browsing the SD Card with ES File Explorer shows what the SD card looked like before connecting to the computer, but not updated files and folders after editing on the computer.
3. Charging is just slower than hell, even without any 3G.
Continuing to test.
It may be time for you to buy a new charger/USB cable.
If you are still using the stock USB charging cable, they are faulty and have a very limited life span that varies from only a couple weeks, to a couple months.
Visit your local electronics store, and pick up a new charger.
sent from my un-dead sammich
Thanks but the charger has nothing to do with it. I have tryed three different chargers. The phone charges on other roms.
Looks like AOKP is passable. I'm going to enable AOKP nightlies and see what happens.
Also, since goo.im is apparently unstable at the moment, I'm going to be pushing nightlies to the other two mirrors as well.
vmroms.com/~vmstorage/quattrimus/
tdm.simplydev.com/roms/quattrimus/
does this mean AOKPb1p1 has been fixed? or am I looking for AOKPb1p2?
SO STOKED!
So it only doesn't work with Quattrimus??
Have you tried flashing back to other ROMs that it worked with??
Did you do a clean install of Quattrimus??
Are you plugging the charger in correctly??
Do you have power running to the outlet/USB port??
well it works great on VS660! :D
although the only 2 issues i got was that
the mic was to low, people couldnt really hear me much.. I had to scream lol
and that the internal space was wrong lol I installed a few apps and it said i used 4.2MBS
and after a bit I couldnt install more even if i unistalled apps
Reactions: tdm
anyone getting a weaker 3G signal than before? when I was running CM7 I had a bad signal at work but enough to stream Pandora, now I can't get it at all. just a tad worse than before.
sent from space.
sent from space.
It's a known issue amongst ICS ROMs for our devices.
Checking a service map, or performing a PRL swap may aid you. YMMV
Status
BrüZZi
