ARCHIVED: [ROM][ALPHA] quattrimus ICS
Status
Not open for further replies.
Re: [ROM][ALPHA] quattrimus CM9 (ICS)
Thanks for all the testing.
Can anyone tell me what audio routing does not work on alpha7? It looks like headphones (music) works. I've been using bluetooth audio on alpha6 and I'll be testing it again tomorrow morning for my workout (with Pandora, finally!)
Do wired headsets work for calls?
Do bluetooth headsets work for calls?
Do bluetooth speakers work for calls? (I can test this tomorrow)
Any other audio things that do/don't work?
Thanks!
Hey guys, just flashed, and my headphones work fine for me. Using Spotify.
Headphones work for me.
Can't get Google Play Music working - (I think this is what most people are talking about when tlaking about music not working). Closes everytime. Any ideas.
Get a logcat.
Is Google missing for a reason I can't find it in the market or do I need to flash seperate gapps. It asked me at start up if I wanted to use Google +, I think I'm forgetting to do something
Camera isn't working for me. Black screen. Not a big issue for me, just thought you might want to know.
Music plays just fine for me, what's wrong with your audio? Are you having any problems with 3G?
nah idk im about to flash it in a bit and test it out then see, last time alpha 6 the 3g was fine c:
I have the same issue but camera quality is good and so is the quality for screen shots. It takes pics which is better than it did in alpha 6, I'm happy with it :)
All you testers are supposed to say this update is perfect and better than iho, I want to make the leap to ics permanently, but I have been spoiled with the perfection of iho for so long that it would have to be just short of curing cancer to become my "daily driver" awesome progress so far. I can't wait to see what's coming ahead with ics.
Radio works on it :) I can't live with the radio and music, I tried to install dsp manager but this from won't let me install it so I'm sticking with a equalizer works pretty good to kill some the feedback with head phones installed
I bet it will after alpha 8-9 its almost done I think well the hard part is over. Ima donate at least $50 I know its worth it.
TDM noted in the relese camera.will.be.black! photos will work but viewfinder is black! its a known issue no need to post
Just finished reading from post 103-122
Really good job working on this Rom. Looking forward to see wen 3g works to use it as a daily driver. Appreciate the work bros:)
Rom seems to be working well, it needs scrolling wallpaper tho......
I just installed it and the only issue I am having is the mms. My 3g works very well tho... Wifi didn't work at first but I toggled airplane on and off, now it also works as supposed.
Music and video( from youtube) work very well also. I downloaded music player and no issues so far.
Thanks so much for this ROM guys.
Ohhh, and the audio problem im referring to is the sound sounding really bad, like super treble. No feel you probably wouldn't notice unless your tone deaf.... Like there is no EQ O.o
The wallpaper not scrolling is due to Trebuchet. It scrolls just fine in other launchers.
As far as the sound goes, I was having similar problems before, but found a nice equalizer in one of the markets that really works quite nicely. I currently use my phone as an alarm clock, and use a playlist as the alarm. Pretty nice to wake up to in the morning.
@TDM: Fabulous work. Everything worked as promised, I have had no problems of any sort. I'm lovin' it.
Status
reblkari666
