ARCHIVED: [ROM][ALPHA] quattrimus ICS
Status
Not open for further replies.
Re: [ROM][ALPHA] quattrimus CM9 (ICS)
Anyone having an issue with charging? I'm trying to charge via USB cable through laptop, and it'll take a bunch of plugging in and out to actually start charging it.
Otherwise, this is working great. So smooth and snappy!
I had a similar issue, but a couple of reboots cleared it up and it's charging from my laptop right now.
Great Rom! This has been my daily driver for about 2 weeks now and A7 is a huge improvement over A6. Thanks TDM!
yeah, my wall charger works just fine, but my car charger won't work.
I am getting a ton of freezes setting up Gapps on the initial boot.
Its freezing most likely becuz its conflicting with the gapps that is flashed already when u flash this rom that's one of the good things about this build no need to keep a gapps.zip file around
S
MMS isn't working for me and my sdcard keeps unmounting... other than that its stellar
S
Ah I didn't know Gapps was included in this build. After the initial setup everything is hunky dory. Great ROM. Love the tactile feedback.
Reactions: tdm
Please test with the new alpha7 to be released later today. wpa_;supplicant has been upgraded to v0.6 in ICS and I previously was telling the system that it was using v0.5. alpha7 will be compiled to use v0.6.
After some testing there is still a problem by wat u can understand after reading the wpa_supplicant found in etc there are some values missing from each network block i would guess meaning something is not letting the AP's RWthe file. maybe a driver? Def something thoug.yet ad long as u can edit it it starts to let the network through I also found that setting the IP con figs manually in network advanced settings didn't cause this to happen.
Reactions: tdm
I'm not using any 2sd... it just started unmounting. Hope I'm not headed for curiousnoobs problem.
Bluetooth and car
My car Bluetooth does not work correctly. My ov and car think they are paired, both ends of the connection ring when called, but conversation does not go through in either direction. Also, the icon on my phone for my car show earphones instead of a phone icon. I guess my ov thinks my paired car is a set of earphones. I don't know.
For everyone involved in the development of this ROM, thanks for your effort.
I get the same message as far as mms goes. Camera started working. Am I the only one who's phone is running hot ?
My phone gets warm also. I bumped up the clock speeds to 480/805mhz with the SmartAssv2 governor, and it seems to get less warm.
I just flashed it, for the first time! And I got 3g to show....but I had no 3g data. Could some one tell me how to fix it.....I only toggle airplane on/off.
thanks!!!! Cool rom.
Reactions: tdm
Tested last night for a few hours. If I wasn't lazy about getting my apps back it would have been my daily rom. Faster and more stable than I expected. After I restored backups with titanium, it would reboot often. So at that point laziness kicked in and I went back to iho.
Question, the encrypt phone setting, does it work? I'd test it, but i dont feel like wasting an hour of my life to find out it doesnt
Had the same 3g issue but when I wen to an area with better signal it picked up and did not disconnect anymore in lower signal areas
Status
DannaOgle83
