ARCHIVED: [ROM][ALPHA] quattrimus ICS
Status
Not open for further replies.
3G streaming works
Sent from my Ice Cream Sandwitch using Taptalk
Re: [ROM][ALPHA] quattrimus CM9 (ICS)
will not let me add my g mail account without wifi anyway around that? i dont have wifi
Sadly I had to go back to IHO for now. Not having bluetooth headset for calls is a deal breaker. Who'd have thought something people rarely use could be so important. But the time I have to call people I'm usually in the car and I don't talk on the phone unless I have my headset on.
Keep up the good work. It was painful having to go back because I reeeeaalllly like quattrimus.
Just a word of caution when switching back to Backside IHO (or vise versa) and you use Link2sd. You're going to want to reformat your 2nd partition before restoring apps and linking them. You'll have nothing but problems and eventually have to do it anyway if you don't. With minitool partition wizard it's a 30 second or less process to format it and it will save you an hour. Found that out the hard way!
Need some WIFI help. I am using the WIFI Tethering app from google (I know its beta) and it works but, It insists that my passphrase on WPA is too short. the specks say min of 8 characters, mine is 12 and it works on every other device I have. I like having a common passphrase.
Does anyone know a way around this? The app is great otherwise but I would like to use WPA.
well i would use it but my internet wont work:( and i dont have wifi i really enjoyed it thow thanks:)
Internet works just fine... I'm currently typing this on quattrimus. You just need to toggle airplane mode and then datao get 3G to work.
Reactions: blizard
For me, I had to toggle airplane mode on / off and then rapidly toggle mobile data on / off 6-10 times in a row to get it to connect. Why? Who knows, but once it connects it does work fine.
im all tp happy with quatrerimus!
people made it seem ICS on the V was imossible but lookie here!
I am truly addicted to this forum lol. Every time that I get on the internet somewhere I check to see what is going on here. I have been using Alpha 7 since Mar 12th as my daily rom and to be quite honest it is great. ICS and CM9 and all of the eye-candy and usability that comes with is amazing. The only things that I have seen that are not working correctly are the common no camera preview, no video camera etc. I have figured out how to get 3g working every time by accessing the *#*#DATA#*#* menu, turning radio off, and then back on and then it works great except for the fact that my phone reaches a good 102 degrees while 3g is on, so I just leave it off until I need it for fear of overheating. I also noticed that I cannot over clock as high in this rom as I can in BACKSIDE but that hasn't proven to be a problem as Quattrimus is quite fluid and snappy on its own. Thank you TDM and all of the other Devs that are involved with the development of this rom for all of your hard work! Keep it going because I am dying to see how the update turns out! The anxiety is killing me.
I'm sorry but without 3g can we still recieve SMS or calls?
Yes, these just go through the network. You cannot receive or sendmms without 3g though there are a few reports that it doesn't work anyways
Sent from my VM670 using Tapatalk
Reactions: drm1992
well so far this works alright but I have to wait for the rom to mature it is not quite there yet as far as data handling goes I can't get grooveip to connect via 3g and that is a dealbreaker.
3G woks but thje rom is rough around the endges
This Rom is amazing, I rocked it for a few weeks and I must say that the only problems are the lack of mms and drop that happens with 3G. Tdms kernel did wonders for alpha 7.
Sure has worked well for me. I'm always looking forward to updates, as each one has been a significant improvement on an already awesome ROM.
P.S. Has anyone else had trouble disabling the boot animation? I have it turned off in settings, performance, but it is still there. I can always just delete it, but I would rather turn it off.
Is the iscream kernel needed to be flashed, or is it built in?
Sent from my VM670 using Tapatalk 2 Beta-2
Tdm has his own kernel he's made, and it's included in the ROM's zip (so yes, it's built in). The iScream kernel didn't work too well with the ROM.
Reactions: Discovered
Status
redmercer
