ARCHIVED: [ROM][ALPHA] quattrimus ICS
Status
Not open for further replies.
Re: [ROM][ALPHA] quattrimus CM9 (ICS)
clock stopped working. Getting a error every time I open it. Fixed theme not working. just had to reboot.
I did, I wiped dalvik, data, cache.
What's a df?
try--- copy sd to pc> disable usb storage and remove>enter recovery>wipe all3x (including delvik)>format all 1x (including sd)>remove sd>copy sd from pc back to sd>replace sd and mount if needed>reflash rom>reboot... :-)
Like this:
adb shell df
Paste the result here.
Listen to the man. Anyone who has a Debian logo for their profile either knows what they're talking about, or is really good at pretending to know what they're talking about.
Reactions: anthonycr
Oh, how I'd love to get my hands on an ICS ROM, mostly for one reason... accessibility. ICS is supposed to have better accessibility support then Gingerbread, and since the bluetooth keyboard I bought decided to go belly up within 2 weeks of buying it, I'm a bit limited in what I can do with the V. ICS and it's Explore by Touch feature would help, and at the moment, the camera and MMS aren't big musts (although, the bar code scanning I do when shopping with the V is a major plus). If someone's got a link to the absolute latest version of this ROM, I'd be seriously greatful.... Finally, a huge thumbs-up to TDM for putting this ROM together.
P.S. -- Is there an easy way to use ADB to do the legwork of wiping/flashing/etc when I'm ready for a new ROM?
The latest version is available in the first post of this thread.
Sent via the Postal Service
I wonder what would happen if I mixed CNA and Quattrimus together... should I try?
I'd Put CNA in a folder cuz its smaller, then add the rest of TDMs Rom and not overwrite anything. just add. and then add The reloaded cm9 tweaks, and beats audio. Worth a shot. Im going to nandroid backup anyway
If you switch anything other than the stuff found in system/app it will probably give you problems. Its worth a shot though.
CNA doesnt have youtube working everything else works. Plus there is more custimization
Tdm, what would I have to change in cna to make youtube work?
Status
lphilpot
