ARCHIVED: [ROM][ALPHA] quattrimus ICS
Status
Not open for further replies.
Re: [ROM][ALPHA] quattrimus CM9 (ICS)
For some people it does for others it doesn't for example me lol
Sent from my LG-VM670 using Tapatalk 2 Beta-4
Really i thought it wasnt working for everyone im expirencing data problems and low signal reception:'(
MMS kind of works for me, I get the option to download the messages but my 3G is so spotty that I can't completely download the message. Lol
Reactions: mazucar
I get that option too I can never download....sadly lol
For the 3G, anybody try this with the new radio flashed?
For the s/w buttons, the screen is small enough as it is...just sayin....
Sent from the BACKside of Tapatalk
I'm using it with the new radio right now. I flashed the radio while on quattrimus... no problems. I haven't seen any changes with the radio.
Sent via the Postal Service
Have you tested any other Roms with the new radio? I'm just curious, as some people report better performance, while others see no difference. If we knew which camp your phone falls into, that could help. The biggest reason I haven't flashed the radio update yet is my rule is never to do anything I can't undo.
I have used it on backside as well and saw no difference. I live in new York so that might have something to do with it.
Hi there I first of all just wanted to thank you for your continued work on the lg optimus v and porting ICS. I was just wondering if you had any nightly builds available and if you have fixed any of the bugs that we are having especially with the camera and 3g. Thanks in advance and if you want i am fully willing to put my device on the jopping blocks to continue to test this rom and report feedback back to you.
You should just read this thread. It contains absolutely all the information that there is about this ROM.
Reactions: dwappo
I'm using it on BACKside and I now get a steady, solid bar at home. I hope this isn't frying my head more than usual...lol
Sent from my GT-P1010 using Tapatalk
It has nothing to do with the ROM. Some people will see better reception, and others won't. It can't -hurt- you to flash it, as long as you follow the warnings / instructions. My specific case, it helped my reception out a pretty decent amount, especially at work, which is where I saw the most trouble before.
Did you originally have a 2.2.1 or 2.2.2? Some people are saying the radio may just be the 2.2.2's radio.
2.2.1, although I thought I read that this radio update is a much higher version number than on the 2.2.2's.
i think it was designed to stop 2.2.1 tethering
Tethering still works fine.
The radio update? The whole purpose was to stop tethering on 2.2.1 phones.
Sent from my Ice Cream Sandwitch using Taptalk
I'd like to hear the differences people notice on 2.2.1 as compared to 2.2.2 to see if that's the case
Uhh, where is this information coming from? I have the update and can still tether just fine, my phone was originally a 2.2.1.
Status
koltyn
