ARCHIVED: [ROM][ALPHA] quattrimus ICS
Status
Not open for further replies.
Re: [ROM][ALPHA] quattrimus CM9 (ICS)
There is also a .zip file that is flashable through recovery that swaps the home and menu buttons if they are reversed.
Keyswap
Hey guys.
I had this ROM as my daily for a couple of weeks, then flashed the LeWa ROM to try it out. Well, I decided to go back to this one. However, when I flashed this one this time, my home and menu buttons are reversed. I wiped everything and re-flashed, but it is still the same. I didn't have this problem the first time. What can I do to get my buttons mapped correctly again?
This usually means your kernel and keymap don't match up -- one is for the OV, the other for the OS. Either that or you have installed a button remapper and forgot to uninstall it.
I think the whole "JB" comment was a joke...
lol.. wow... one person got the android5 reference... and yes it was a joke... I figured tdm would get a laugh out of it... sorry to everyone who missed it... ;-)
I didn't know what a button remapper was until I had this problem. I flashed the quattrimus ROM and the iscream kernel just like before. Should I try the ROM without flashing the kernel?
Yes you should. Tdm built his own kernal and its included in the rom. It runs great
Sent from my VM670 using Tapatalk 2 Beta-4
Reactions: bray462
Idk if people have suggested this or just haven't thought of it...but is there a way so that the rom can work off the SD card so tdm wont be worrying about the work space.
lol, i think he's working on AOKP.....and trust me. it's worth the wait. ;)
Gannon did say he stopped working on AOKP, and he did say tdm's taking over for him from now on. A.P.P is working together on all sorts of ports, and it's all worth checking out.
Sent from my LG-VM701 using Tapatalk 2 Beta-3
I see the last updated version is from March 12th on the first page. Do we know if and or when the next version will be available so we can try it out?
Status
Sonfollower28
