[ROM] Android Open Kang Project
How does one set "Franco" as the default ?
In what setting using AOKP ROM
Sorry if I confused you, all I meant was don't change or lower the CPU settings with apps such as SetCPU. For example, you could set the minimum lower than Franco's 700 which is the default setting. I changed it to 350 while the phone was not being used and the Max at 1200 CPU. Once I did this using Franco's app in the market, I got really bad battery life. It didn't make sense why lowering it would make it worse but it did. So I charged my phone back to full, went into his app and under kernel settings I changed it to 700 minimum and applied settings. Afterwards, back to the amazing battery life.
There is a way to underclock the kernel and its laid out in its own section in the app. Also, the one change I would recommend is enabling Hotplug as it shuts down cpu1 when the screen goes off. It comes back on when you use your phone. I would recommended downloading his app if you use Franco's kernel as he explains everything in great detail, plus why not support the dev. And, you could download the newest update right from the app and it will be ready to go in CWR.
Reactions: TheGreatZhuzhu
I've run every version of aokp and between this and rootzboat I'm happy just can't choose which is better aokp has more options bit at times more bugs rootzboat has run without a single issue each version
If the OP doesn't have time to update the thread the thread, I'll definitely help as well.
OP here...
I'm not sure what updating I would do :). I originally started this thread because I came across the ROM over on rootzwiki and saw how big it was. I was just wonder if anyone here was using it (I'm a pretty happy Codename user myself)? I think a mod changed my title to make it more of a formal "ROM" thread. I'll go ahead and throw a link to the original web page so people can easily navigate to it.
On build 21 right now. No problems yet and it feels so silky smooth. I can notice a big improvement over last build.
For the record I'm running franco14.2
I am loving this rom. Worth the flash
my galaxy nexus is no longer reading my media files on this rom or any other for that fact. is this a common issue? what do i have to do to fix it
How did you install? in ROM MANAGER or in Recovery mode?
Did you do a full wipe of data, cache, and dalvik cache?
Did you restore data thru TiB?
Did you make sure the rom download was good by checking md5?
in recovery
always wipe a few times to be sure
i didnt restore anything through tib although i have things backed up
i didnt check the md5 through kang but its not working on codename and i know that the md5 there was fine. When i reflash codename the music still wasnt available.
installed in recovery
wiped a few times to be sure
i didnt restore any data because it auto synced through google
i didnt double check the md5 but im pretty sure its not working in codename and i know that md5 was fine. I can still play all my music through the file explorer but thats seriously annoying
I used the gapps that are posted with the rom just to make sure of no issues
I love how you can remove the clock AND the battery icon from the status bar. Just leaves the bar so clean.
Same here I like a clean notification bar .
I already have a clock on my weather app and prefer the Miui style battery bar
Flashed AOKP today and I'm still tweeking things around. Love it! Running build 21 and having Nova Launcher built in is awesome. I'll probably stick with this for a while.
Darek
