[ROM] Android Open Kang Project
Thanks, I'll give it a try :) There have been a few times after flashing I forget to write something down that I needed.
Lol no prob.. yeah I still forget things sometimes. Its always great to have a list.. used to keep a post-it right behind my computer on the wall with reminders on what to do before flashing (tibu, sms backups, etc) and what to set back up after flashing (ringtones/sound settings, other random settings I'd otherwise forget, things to restore, etc). Now it's all second nature :)
I know that flashing a new ROM doesn't kill the SD card, but if you don't backup photos, will they be deleted? I do a scheduled backup for MyBackup Pro and include photos, but I'm not sure if I really need to. lol
Nope you don't need to. If it's on the sd card its safe.
As a rooted, flashing, active user... its ALWAYS a great idea to keep things backed up somewhere else JUST IN CASE something goes crazy wrong. I keep my photo's synced to dropbox nowadays... you can also use just your gmail account (google+ or picasa sync) or plenty other options, and I have my backup data (via tibu) synced to the dropbox as well. Its just for piece of mind really. But no, in general you shouldn't have to worry.
Reactions: 7stringer
No, they should stay there regardless if you want them to or not ;).
I'll likely try to backup my photos once a week to my computer - hopefully there's some way to do it wirelessly. I have the G+ sync on, which is nice, but I'd rather have them in my iPhoto library on my computer.
I have everything sync to Dropbox, so I can set it and forget about it.
Went ahead and added the dropbox app. I think there's a way to have it sync into my iPhoto album anyways, which is exactly what I want. Thanks for the tip.
I don't have much of a problem restoring things back to where they were and if I forget those I guess it wasn't important enough anyways. I had to restore backups a few times just to get a phone number or something else that was sent to me in a text (guess I'm just getting old LOL)
Can you check to see if GPS works on O3 for you? GPS wasn't working on O3 for me.
Sent using Tapatalk 2
Appears to work.
hiredbyskill
