[ROM] Android Open Kang Project
I'm using a GSM Galaxy Nexus (bought from the Google Play store). I flashed the Franco kernel nightly 181. When I was using the wheatley governor, it did some funny things with the display. At one point it would show snowy looking dots. After rebooting the phone, a gray and white line was showing through the middle. Everything went back to normal after restoring from a backup when I using the Franco kernel milestone 4.
1. You can get the Verizon Login Client here: https://m.box.com/view_shared/6ca25ad7422ace3519a5
2. Try out Wheatley for battery life. I'm finding it to be quite good!
OK, so I downloaded installed the package and tried log in but get the error message that services are temporarily unavailable. And won't let me login.
Any ideas, AOKP b38 and Franco m4.
m38 seriously is the worst release yet of this rom......signal is non existant.
if I roll back to milestone 5 do I have to restore from a nandroid or can I just reflash the rom?
You could do either... However, I disagree completely. 38 is very solid I've had no issues, and a ROM isn't going to have any effect on your signal anyways.
If you're having noticeable issues in the usual places you don't then it's more likely just VZ network issues. That's also assuming you haven't changed your radios since. But yeah the ROM really won't have any effect.
yeah usually it shouldn't but this one is.
Same radios, same locations.
No signal in Hoboken, NJ today in numerous locations.....No signal in Basking Ridge, NJ along Rout 78.
No signal in Bethlehem, PA Lehigh University. Problems I had with 4.0.2 that disappeared with the 4.0.4 radios but with this nightly it's bad.
What app are you trying to open? After installing, all I did was run the NFL mobile app and it went through.
Trying to access My Verizon Mobile to check account usage and such. Did not try NFL.
My favorite ROM so far. My one gripe is you lose the bookmark pop up shortcut in the browser when you long press the back button. My options are to either enable the quick menu in labs or access the bookmarks by flick scrolling to the address bar and going in that way. Any suggestion?
Did you download the Nexus only version from the play store?
You could also tap on the menu button at the top and then tap on bookmarks.
I wasn't aware there was a shortcut to the bookmarks in stock ICS. When you say hold down the back button, are you referring to holding down the back soft key button?
When I go to google play search my verizon mobile, select the galaxy nexus, it tells me I already have it installed (done on a PC) i tried on the phone, doesn't even show up. I have gapps installed obviously and can download apps, either by PC or phone.
Also when I check apps, I only see My Verizon Mobile, when I just tried it I get message Unfortunately Verizon Login has stopped.
Xanth-
Thanks. I was aware of the flickscroll to top/menu->bookmarks but miss the one click option.
There is an browser shortcut to the bookmark folder in bone stock ICS. While in the browser, at any time if you longpress the back button softkey your bookmarks folder pops up. Once I discovered it I got very used to it. I find accessing bookmarks any other way clunky.
Xanth-
Hi Xanth,
Just to be sure, you downloaded this one here right?
My Verizon - Galaxy Nexus
If you got that one and you're still getting an error, try going into app details and clearing cache and data. Then go into recovery and clear cache there. Reboot and try to see if you can log in. If not, chances are something funky happened and you might need to do a clean install of AOKP and GAPPS.
EDIT: I just realize that you aren't the only one having this issue after reading some of the feedback. Ok, this isn't your problem but rather a VZW issue.
I get the services not available error if I try to login for the first time while on wi-fi. Shut off wi-fi and give it a try. After the initial login I can use the myverizon app from anywhere.
Hi Xanth,
Click to view quoted image
OK went in to apps, I only see my Verizon mobile nothing about Verizon ans nexus. Cleared cache there, turned off wifi and reboot, same issue. Which cache to wipe in recovery?
Not sure if it stopped when I changed to AOKP or vz had a update to myverizon app. Maybe there's a newer apk.
I have actually noticed problems too. After flashing b38 I had random data drops, an issue with my dialer that would sometime bug out and bring up an "in call" screen anytime someone called me so I couldn't see their caller Id, and worst of all it would randomly put the person on the other side of the line on hold mid call. I would be talking to someone and suddenly they'd be like "hello? Hello?" I'd look at my phone and it would say "on hold".
As far as this last issue, I just got 4g last week in my area, hope that issue isn't related to that. I reverted back to a Android of b37 and am going to stay here for a while to make sure everything's good.
I've experienced data drops as well. Thinking seriously about going back an update. Not liking b38 right now
arent data drops related to the radios? i am experiencing these too, my 4g keeps dropping off to 3g, and im in midtown NYC, supposedly my lte signal should be quite strong.
this is the worst time for data issues, i need to watch my footy at work!!! lol
Radios + kernel can affect data signal and drops.
Reactions: oxymoron
liquidsnake757
