[ROM][AOSP][10/31][JB] Bugless Beast VZW Galaxy Nexus
Hey guys - I just wanted to check before I did it:
If Im already running the 7/12 version of BB...do I need to do a full wipe before I flash 7/13 version??? Or can I just wipe dalvik cache and get on with it?
Thanks in advance.
According to Peter himself, no need to do a full wipe. He said just wipe davlik. I did cache first, then davlik. No problems here.
Reactions: Bleezy
Thanks in advance.
In the case for 7/12 to 7/13 Pete specifically said flashing dirty was OK.
Had two random reboots with spotify today. Argh.
Sent from my Galaxy Nexus using Xparent Cyan Tapatalk 2
Reactions: robertvito
Re: [ROM][JB][AOSP] 4.1.1 Bugless Beast VZW Galaxy Nexus - 7/13/1
I have a JB Enhanced Power Menu and a T9 dialer that I was using on JellyBelly. Will they work with Bugless Beast? JB should be JB right?
Bad assumption to make.. Different roms are different roms. If it isn't confirmed to work on this rom, you can always make a backup and try it so if anything screws up just restore your backup.
Very very true. However, I am pretty adventurous and have flashed a large menu battery percentage, and reboot menu mod from jelly belly onto bugless and they are working fine.
I dirty flashed as well and no problems at all
I was in spotify all day and didn't have any...I did see that back with early versions of JB on other ROMs...did you wipe before loading BB?
Okay I googled for 15 minutes and couldn't find the solution, although I know that I read it before in the past couple of days... How do you get the navigation voice to work? Was this fix the libpatts file? If it is, I don't remember where to place it. Anyone?
First time rooting and installing an OS, courtesy of Root Toolkit V 1.5. Everything is great so far, about time i took full advantage of this device.
Has anyone else had issues with the camera not being able to take another picture? Whenever I take a picture, it has the little animation showing the picture sliding away, and then it freezes on the previous picture and I can't take anymore.
Did you do a full wipe before flashing?
Just a quick question...I haven't tinkered with wallet much since I first got my nexus in December. If BB includes wallet should I reset from inside the app anytime I flash anything new?
I just restored a nandroid from January to reset my wallet data (I didn't do it before, but haven't installed wallet since). Am I safe to flash BB and activate wallet now? Thanks a lot
I gave this ROM a shot...I liked a lot of it but I'm sure more is to come - I'm going back to my nandroid for now but I'll be back.
You should be..
just installed franco 220 will see how it plays with BB.... will post the results in 24 hours but so far so good
I've been having quite a few problems with bugless 7/11 version..
It seems to be draining my battery even faster than Vicious Liquid v1 did (and it that drained it quick!!)... My widgets like my clock doesn't update with the current time, and my battery widget doesn't show the right percentage.. I did a full wipe as well.
I know a few people have commented that they have seen less than great battery life on Bugless. I'm not saying that is or is not the case but a few comments about battery life in general on ROMs just to keep some of that discussion in perspective.
It can take up to a few charge cycles before the ROM will settle and the battery life you are seeing is normal. If you don't have 2 or 3 cycles (0-100% battery travel) on that ROM flash, then the battery life you are seeing probably isn't accurate. Furthermore, flashing an update as I understand it will start that process over. Right now Pete is banging out updates almost every other day so if you are flashing those the chances of you seeing accurate battery stats are slim because you aren't getting enough charge cycles between them for things to settle and calibrate.
Additionally, when you first flash any ROM you can kill the battery. I flashed Bugless on the 7/13 build and went from 100% to 85% just from backing up and flashing. If you flash at 8am and use your phone for a few hours without charging it again, yeah you'll see crap battery because you sucked up a ton of juice installing it.
Oh, wiping battery stats in CWM doesn't do anything for you battery life. Throwing that out there since I still occasionally see people suggesting that.
I've been running Bugless now for a while now, on several different phones ranging from the OG Droid up to the GNex. My experience has always been that the battery life is as good or slightly better than stock, that applies to the latest 4.1.1 version as well.
Battery life is also very hard to get a good grasp on in just a few days. So many things come into play. There are days at work when I can be at 30% by lunch time and other days I have 60%+ left. Just depends on how i'm using it that day.
So just somethings to keep in mind as you see people post their experiences.
This. :)
Pete's saying a new build is coming tonight that fixes the 5ghz WiFi issue...
Here's a change log too...
http://www.peteralfonso.com/2012/07/bugless-beast-41x-jelly-bean.html
When I try to paste the stock browser in the system/app directory it says the folder is read only. Am I missing something?
birdsong2000
