[ROM][AOSP][4.0.3] Codename Android 1.5.5 [Full Open Source]
Re: [ROM][AOSP][4.0.3] Codename Android 1.2.0 [Full Open Source]
FLASH GAPPS! They included the apps but something is borked. Reflash gapps after ROM flash.
DO IT.
I can't for the life of me figure out how to get a persistent search softkey...the only option I'm seeing is to get rid of the multitask key and substitute in the search. Can we no longer have both?
This is a known bug.
Ill be awaiting the 1.3.1 release =D
DO IT.
I didn't need to flash the gapps after and everything is working fine. My gapps are there too
Anyone else having a gapp issue ? The instructions say gapps are included so no need to flash them seperately.
FLASH GAPPS AFTER ROM!
I know it says included, but something is borked with the market auto-restoring your apps.
If you don't mind them not being auto-restored, don't flash GAPPS, if you do - flash them!
I had to go back and it worked fine, without them flashed they wouldn't restore. It's a known issue at this point over at Rootzwiki
Cheers :)
ya...mine didn't autorestore either. wierd....wallet, maps, earth....all came with the rom but market wouldn't auto-restore titanium or other 3rd party apps. Went back to 1.20 and figured i'd wait a while longer...
Same here.
Curious as to why you need the market to auto restore. Just download the free version of Titanium and restore all your apps and data. You could also use "restore market links" within Titaniums settings if needed.
didn't know about "restore market links"...
i did go ahead and download titanium again and restore that way. but having to do it this way made me nervous that gapps may not have been installed correctly and figured i'd go back to 1.20 until it was.
probably being over cautious but meh....1.20 was good to me....
anyone using Franco's kernel on 1.30? how to u like it compared to the default kernel?
I'm hoping 1.3.1 will release soon with some key fixes....going to stick with 1.3.0 for now out of laziness.
Edit - looks like 1.3.2 is out!
I'm sure the newest 404 update release should roll out soon. It what I've been waiting for.
Flashed and its nice. Stronger signal seen right away. I'll report later how things run.
pmm09
