[ROM][AOSP][4.0.3] Codename Android 1.5.5 [Full Open Source]
Since the ROM is AOSP based it will not be updated to 4.0.4 until 4.0.4 is pushed to AOSP, which it strangely hasn't been yet. Until that happens don't hold your breath :)
Sent from my Galaxy Nexus
anyone have issues with the launcher? It's really, really, bad for me.. And it even reloads itself.
I'm not on this current version. I'm on 1.1.4. Is it using nova launcher?
I'm using Nova launcher with 1.3.2....only time I ever have problems is after making a screen backup, the dock will redraw every time you return home. Seems to be a bug with Nova after backing up that doesn't go away until you reboot.
bummed that 4.04 isn't included yet.
friend put 4.04 on and has better signal strength and better 4g coverage.....
can't wait for that!
I installed nova as a system app v12, and updated the app via the apk to v13 and everytime flashing a rom I have to reinstall v13.
are there any new versions of nova yet?
sorry for being away....on computer lockdown at work!
Tony you can use the 4.0.4 radios.. no problem at all.. They're an improvement, not life changing, lol..
Here in CWR just wipe cache and dalvik and flash: http://dl.dropbox.com/u/47300967/Imm30B_radios.zip
This updates your bootloader as well. Don't feel nervous everything works totally fine :)
@Tony ....v13 is the latest. Since the system is re-written/wiped during a ROM flash you will need to re-install it every time. Make a backup of Nova with Titanium and just restore Novas app/data after flashing an update.
Question for you. New to ROMing. I thought that I was not supposed to backup and restore system apps, only user apps. Are you saying that Nova is a special case and it is ok to restore it after flashing a new ROM?
I've been doing it with every ROM update without a problem.. on AXIOM and CNA ...but yea, you normally don't want to restore system settings. Just make sure you have a nandroid backup just in case you do experience any problems.
Reactions: ScooberJake
Big trouble here. I have flashed without wiping data. Totally forgot. I am missing the calendar app from the device. Thoughts?
My first thought would be to wipe the data and reflash. If that doesn't work, restore your backup, then wipe and flash as if it never happened.
Reactions: tony bag o donuts
Looks like the next big update for Cna will be Friday and will include the 4.0.4 files according to his twitter :)
Yes I saw... Well.. I guess you can hold your breath til friday then :) lol
Ha, ha!!
I've been hitting every other update for some reason so I guess I'll just wait till Friday and keep the cycle going. LOL
1.3.3 just dropped!
CHANGELOG
### 1.3.3
* common: fixes google wallet
* common: fixed set on boot in new overclocking settings
* common: adds option for either replacing recents with search or having all four
* common: update maps and google wallet
* Galaxy Nexus (CDMA): updated to 4.0.4 proprietary files
* Galaxy Nexus: Codename Kernel 1.4.0 (Upgraded to 3.0.20, Enabled CP210 drived for usb serial, and added ksm)
The change to allow both the search and recent apps soft key is a welcome one. Plus, it is good to see that Google Wallet is working again. I use it on occasion and good to that it has been fixed.
Sent using Tapatalk
The OP has been updated with 1.3.3 :)
Let me know what you think I'm currently playing with AOKP but I'm always itching to flash something new.
Welladjusted
