[ROM][AOSP][4.0.3] Codename Android 1.5.5 [Full Open Source]
Sweet. Hoping this rom and new radios = better battery life. What's your dbm @? Do u think there better then before?
Sent from my DROID RAZR using Tapatalk
Dbm is at -75. I've never looked before this. I'm in a 4g area but only use 3g
PHone wont boot up after flashing 1.3.2. update dont know what happened? any help would be greatly appreciated . Thanks
i was updating codename and not sure what went wrong. phone wil not turn on but i can boot into recovery. going nuts here
Did you do a full wipe before flashing? Also, did the md5 checksum of your download match the one posted? Could be a bad download.
Sent using Tapatalk
Thanks ill try a diffrent download and see if that works thanks
It's a good practice to check the MD5 checksum of the download to confirm that it's good. I rarely have a bad download but it happens sometimes and you'll definitely see issues if the download is bad. Good luck.
Sent using Tapatalk
Has anyone flashed the new 4.0.4 radios over this ROM?
Here they are if anyone wants to give it a shot.
[RADIOS][Galaxy Nexus] All available radios/basebands - RootzWiki
Flashed the 4.0.4 radios and working fine so far. I'll see how things go with some longer use. I had avoided flashing the new radio leak because the prior versions floating around supposedly couldn't be flashed on a 4.0.3 ROM, but the zip files in the link above can be flashed with any Galaxy Nexus ROM in clockworkmod. Will report back with any issues.
Sent using Tapatalk
Re: [ROM][AOSP][4.0.3] Codename Android 1.2.0 [Full Open Source]
Just installed the 4.0.4 radios... Note: I live and work in very poor reception areas so I'll let you know in a day or two.
It could be my hopeful imagination but it appears to be a little stronger; albeit, not by much.
My house is far enough outside town that I can't get cable or dsl, my nexus is my internet connectivity. Using the wifi hotspot with the 4.02 radio's I had usable internet, but it would drop connection often and sometimes I had to reboot to get it back. I flashed the leaked 4.0.3 radios and my speeds were a bit faster and the connection was more stable. Almost no drops. I flashed the 4.04 radios a couple of hours ago and my speeds went up a bit more immediately after flashing. Based on 2 weeks of use on 4.02 and 4 weeks on 4.03, I'm convinced the 4.03 radios are better than 4.02. It's too early to say for sure, but so far the 4.04 radios seem to be an improvement too.
panelexchange
