[RoM] AOSP 4.0.3 - updated 02/11
Re: [RoM] AOSP 4.0.3 - updated 01/15
Voicemail settings are only accessed from the dialer app. From the dial pad, menu,settings, then voicemail settings. Delete the *86 that is there and replace with your phone number. Many icsroms have this that you have to fix. Dumb that the dialer settings aren't in the main settings tab... but this is an ics thing not a fault of the rom.
Is there a way to download v5 again? I liked how it ran and I somehow deleted it off my computer =\
Sent from my Nexus S 4G using Tapatalk
I do it by dialing my own number
i noticed on v6 with new google apps that the music apps are missing, but on v5 with the previous google apps that both music apps are present. is there a way i can manually add them to the new gapps zip and flash them?
v.5: both music apps
v.6: no music apps
EDIT: My pictures were undetectable by the camera but they ended up showing up after a while...so very bizarre. Thanks jstntp.
Finally updated to V6 from V5 but want to see if my eyes are playing tricks on me. To me it seems like the colors might be a little washed out. Does anyone else see that or is it just me?
Also, this. I don't know if it's the mere mental power of suggestion or if the colors are actually lighter.
I would recommend a full data wipe and reflash if you didn't coming from v4. And even if you did, might want to try again.
I wish I had a computer :(
if you're already rooted and have CWM installed, you might not even need a computer. you can download the ZIP files right from your phone and install them once you reboot into recovery.
if you aren't rooted, then, yes, you'll need a computer. hopefully one day you won't :)
first time using one of your roms, coming from cm9 and totally impressed, one forced restart right after install but seems fine now thanks for the great rom!!!!!
bah. just like last version, the GPS is broken. it thinks my location is somewhere I was yesterday, and Navigation hopelessly asks me to Follow the Route into infinity.
I need navigation, does anyone have advice?
Did you format boot and system before loading the rom? My GPS works perfect.
Does anyone else notice that when you lock the phone you can see a flash of another screen. This is the only issue I'm seeing.
It's very quick I tried both bugless beast and AOSK rom. Its not a deal breaker its just noticeable.
On V5 it was a bright flash. It seems to be mostly fixed on this version. Its almost a dark flash and super fast so almost unnoticeable.
stoffe949
