[RoM] AOSP 4.0.3 - updated 02/11
Thank you very much. Again pardon the ignorance. This is my first time rooting and i want to get it right. I unlocked my bootloader and gave myself superuser priveledges. yesterday
I am assuming that I will still need to follow the instructions in this post to the letter and go ahead and flash su.zip as well.
Anyway i just dowloaded the java and the android sdk, I subsequently updated it. I am following the instructions in the sticky from: "http://www.androidcentral.com/unlock-bootloader-and-install-su-and-cwm-nexus-s-4g-forums"
I am on the step where is says to:
"go into the Settings menu, then choose Applications > Development > USB Debugging. After you've done that, plug your phone into your computer and let it try to install all the drivers. It'll mostly succeed, but something will be missing. This is where PdaNet helps us out."
I installed pdanet on my windows pc because I saw it as a prerequisite instructions. I believe that it already installed necessary samsung drivers. My issue is that when I plugged my phone in to "let it try to install all drivers" I did not see that occur.
Is that normal? Am i safe to proceed in getting adb? Any help and insight is much appreciated
Start a new thread for issues not directly pertaining to this ROM. Good luck rooting and flashing and you will get more help if its posted.
Sent from my Ice Cream Nexus
wait...just noticed something.
What's the difference between your dooderbutt ROM 4.0.3v1 and this ROM listed in this post?
Dooder is a port from the ics ota from the nexus s on T-Mobile. This one is an aosp build for our phone.
Simple 1% battery mod is up in post #3 for anyone that's interested.
Click to view quoted image
Awesome....thanks! Works good.
Long days and pleasant nights............
Re: [RoM] AOSP 4.0.3
yes GPS! this will be my daily rom untill the official release or oxygen releases a rom :)
- also theres no way to clear all notifications in the drop down ...
Been a full 48 hours since flashing and loving it. First first release that I have had absolutely no issues with. Not a single fc and everything is settling in nicely. Battery life is very good, giving me almost 10 hrs of working time with almost 4 hrs of screen on time, and I expect to get better. Thanks again beezy.
Reactions: beezy
Re: [RoM] AOSP 4.0.3 - updated 12/23
yep...download it from the market
I dl'd it from the Market but keep getting "Login Failed". Can't get Calendar to sync today. Google+ (dl'd from Market) also gives "Login Failed". They both _seem_ to work, but that annoying "Login failed" is driving me nuts.
When that's happening pull down your drop down and there will be an option to grant that app permissions.
Reactions: beezy and jondevere
Did that, but keeps saying "Login failed" when I run maps.
OK one other thing to try. With maps open, press settings and then if there is an option at the top to log in, choose that and grant the new permission in the drop down. I did have the same issues you are talking about and after doing what I just described, maps hasn't shown the login failed message.
Reactions: beezy and kbboykin
Re: [RoM] AOSP 4.0.3 - updated 12/24 Face Unlock
Has anyone confirmed whether or not mms- in works with v2 or not?
vdacau
