[RoM] AOSP 4.0.3 - updated 02/11
Re: [RoM] AOSP 4.0.3 - updated 12/24 Face Unlock
V2 looks good. Able to fix the issues with maps, but can't, for the life of me, get calendar to sync. It errors saying problem retry later. Haven't tried titaniun back from another rom. At any rate, Merry Christmas and Happy Holidays
Reactions: beezy
I noticed that one glad it's not just me but sad that it's happening. We'll check it out see what we can do to get that taken care of,I would leave it unchecked if you notice any battery issues.
Just noticed that I am not able to buy any app from the android market .
Getting error - an error occurred. Please try again.
Can anybody help ??:(
Sent from my Dooderbutt-aosp-v-2 using Tapatalk
Sorry to say but had to move to the latest Alpha build (19) of CM9 from the xda forums as I couldn't purchase anything from the market using this build. Nevertheless i would want to thank the developers for the effort.
The face unlock feature provided is awesome :o
Sent from my Nexus S 4G using Tapatalk
I have a question:
If I install this ROM, can I use Rom Manager to (if I ever wanted to) flash my backup of my rooted stock ROM that I made today?
Yep! Ron manager will take you right back to where you were when you ran the backup.
Just make sure you have a correct backup. Good luck
Re: [RoM] AOSP 4.0.3 - updated 12/25 Face Unlock
For some reason, when i try to enable face unlock in settings>security, it says "Unfortunately, Settings has stopped." when i hit face unlock. PLEASE HELP... great rom though :)
You need to flash the face unlock zip in the extras section of post 1
is there anyway to Save your homescreen configuration when wiping and flashing anew Rom?
Only if u use a 3rd party launcher and it allows u to backup and restore settings.
Sent from my PG86100 using Tapatalk
As was already mentioned. If you have a 3rd party launcher such as go launcher or launcher pro they both have the ability to save your settings. Even if they didn't, you could save them in titanium backup restore app and data and your configuration would be saved as well.
Yep. I've been doing this since using the SDK port in October. Backup your apps and settings with titanium backup (free version works just fine). Then after installing the new rom go to restore, find [Desktop] Launcher 4.x.x. Choose restore them when prompted choose Data Only. This will keep the updated launcher in the new rom while restoring your home screen configuration. Occasionally some apps will say not found (just delete and set again) and some widgets need to be placed again. Folders (which I have a ton of) always restore completely. As I said, I've been using this technique since the SDK port and have never had a problem.
Thank you! That sounds like exactly what I am looking for. To be clear, you are proposing this method for stock ICS w/o a 3rd party launcher, correct?
Is this build basically the build from this thread but updated to v2 and now v3? I just wanted to make sure that I am flashing the absolute latest and greatest, cutting-edge, ROM ever!
Also, big thanks to Beezy and all of Team Hydro for another crazy awesome ICS ROM! You guys are the best!
This one is built from source.....the other is a port of the ns ota.
Long days and pleasant nights............
The other one is a PORT of the Nexus S from T-Mobile. They already recieved their ICS OTA and it was ported over.
anyone get Calender Sync or MMS working?
I heard there will be a update later that has MMS working,i'll check calender out and see what can be done. ;)
Reactions: drummer7
BarishYadav
