[ROM] [AOSP] MMuzzyROM for Toro - Jelly Bean 4.2.2 - JDQ39
problem is I adb is like another language for me.....
Yes, but if you already have it on a computer it's easy to use. Just down load the ROM to your computer, connect your phone, open the command line and type these commands:
Code:
cd <to folder containing ROM>
adb reboot bootloader
sudo fastboot -w update <Name_of the ROM_file>.zip
If adb won't flash the ROM, you can push it to the sdcard and then use TWRP or CW to fash :
Code:
adb push <Name_of the ROM_file>.zip /sdcard/<Name_of the ROM_file>.zip
If you are using Windows use one of the guides to help with the details of connecting your phone.
Yeah but computer can't see the phone.
I tried the toolkit from xda, but now I can't even go into recovery.
I can only get to the screen with Start in green and fastboot below it in red.
If the computer can't see the phone then u have a driver issue. Make sure u reload the drivers from the toolkit, good luck. These phones are hard to brick, you'll get it.
Re: [ROM] [AOSP] MMuzzy's Jelly Bean - 4.2 - JOP40C - New Build!
I'm not sure I understand this part of the directions...
3. Go into mounts and storage
4. Format /system
5. Format /data
6. Format /cache
So, before I wipe Dalvik and flash the ROM/Gapps, I check the boxes within the Mount tab (using TWRP) to "mount system", "mount data", and "mount cache"?
If so, then I've seen instructions that say if I get a system 7 error that I need to go and make sure to "unmount system".
It seems that the data and cache are already checked. Why do I mount the system?
okay....a few more questions.......If I were to run the Superwipe script, do I do that immediately before flashing the ROM?
Also, if I choose to run the superwipe script, do I wipe cache/dalvik and system as well or is that just overkill?
I just format the system and then flash the superwipe script before flashing a NEW ROM. When flashing upgrades within the same ROM is when I go dirty.
thanks...yep just trying to decide between twrp or cm.....I messed up using twrp lol.
I recently installed the OTA 4.2.2 on my rooted nexus.. I re-rooted using Wugs nexus tool kit. I then lost the ability to wifi-tether. Then I flashed Mmuzzy's french vanilla and the native tethering works now without an app.. but only my computer will connect. I can't get my XBOX 360 to connect.. any help would be greatly appreciated. Thanks
You may need to delete the profile on the xbox and reconnect
The whole UI sounds are out of date... I think MMuzzy needs to do a resync
Was there an update to MMuzzy's ROM that wasn't covered here? I did a manual search with GooManager and found that the French Vanilla ROM was updated recently, but it hasn't been mentioned. Anyone flash the 4/26 ROM?
4/19 was the last release. The 4/26 ROM is a test ROM.
This ROM still rocks. Nothing else to say or report, The ROM works, it's stable and it's just awesome. :)
This rom is like bugless beast was. A few tweaks but just works....LOVE IT!
There is a reason this thread doesn't have a lot of replies. The ROM works so well that there is nothing to talk about. LOL
Free bump for the the best Toro ROM.
Or development has stopped since device is 18 months old?
Sent from my Galaxy Nexus using Tapatalk 4 Beta
No updates since April. Wow! Euroskanks downloads are starting to thin out as well, still have my Nexus though! :)
I notice some lag or slowness too-- probably just "buildup". I see reference to a fix for Titanium Backup on some 4.3 ROMs , so I'm thinking I'll move to something using 4.3 after I see TiBu is updated.
Sent from my Galaxy Nexus using AC Forums mobile app
Tfunz
